Provide your email in your profile and I'll send you a sample VAV program.
Hi,
I'm new to the industry and I'm still lost. Can anyone walk me through this Basic air handling unit program?. Thank you in advance.
The variable volume air handler is comprised of an inlet isolation damper, chilled water and hot water control valves, and a supply fan with a VFD.
The air handler will be enabled on a time of day schedule. When enabled, the AHU inlet isolation damper will be opened and after a delay of 30 seconds the supply fan will be enabled to operate and the VFD speed will be modulated to maintain a discharge pressure of 1.5 “wc. The hot water and chilled water valves will operate without overlap to maintain the discharge temp at 55 degF. When the air handler is disabled, both hot water and chilled water valves are closed, the isolation damper is shut and the fan speed is set to zero.
Physical points :
AHU1.SFAN.SS
AHU1.SFAN.SPEED
AHU1.ISO.DAMPER
AHU1.CHW.VALVE
AHU1.HW.VALVE
AHU1.SA.TEMP
AHU1.SA.PRESS
This is my email address, local39.yos@gmail.com
Thanks,
This is my email address,Email Address Removed
Thanks,
Last edited by Chris_Worthington; 05-05-2012 at 07:09 AM. Reason: Email Address Removed
No emails in posts. Please edit it out and put in your profile.
kontrol out
"Good" - Jocko
"Open is as open does." - Forrest Gump
"Can't we all just get a Lon?" - Garry Jack
"BACnet: integration or interrogation?" - The Janitor
"Interoperability? You can't handle interoperability!" - Nathan R. Jessup
“What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
I guess you didn't read the post above yours?
kontrol out
"Good" - Jocko
hi,
done ...check my profile....sorry I am new
