Results 1 to 8 of 8
    Apr 2012
    Uniweld Nitrogen Flow Indicator
    Anyone using nitrogen flow indicators while brazing? I'm inclined to think its a good idea.
    Is the metering tube on top glass or plastic? (Uniweld) I asked @ my local JS typical answer ( Not Sure).
    Thanks for any info. Jay Parker
    Jun 2008
    Rochester, NY
    Its glass and I highly recommend using one. Very easy to dial in a low psi for brazing.
    -Mark
    RSES CM Member
    NCI Certified Air Balancer and CO/Combustion Analyst
    NATE Senior technician - Energy efficiency analyst and 7 other NATE Service certifications
    Never stop learning!
    In the work truck
    THe uniweld one I am pretty sure is plastic. I have a small crack in the outer tube.. Good instrument. Highly recommended.
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    Oct 2011
    Arkansas
    I use a needle valve on the regulator outlet. Thought about buying the Turbo Torch flowmeter.
    http://www.ebay.com/itm/380417574040...84.m1423.l2649
    Feb 2012
    Toronto Canada
    The Turbo Torch One is the one I am going with. It is $40 at our carrier supplier in scarbrough. I seen it at the Trade show its a solid piece made to last but like any gauge can be broken.
    How much is the uniweld piece going for?
    In the work truck
    Quote Originally Posted by #1CDNTECH View Post
    $40.00. I like mine. Johnstone has them in stock where I am.
    May 2010
    Tennessee
    Quote Originally Posted by JAYLUPARK View Post
    Yes its a very good idea. Reason why, click here http://www.youtube.com/watch?v=3uP-eb8Zz08&feature=autoplay&list=ULe26dkmA_CfY&lf=mfu _in_order&playnext=1
    There is an inner tube that reads the measurments and the outer protective sleeve, they are both plastic. Johnstone Supply has them on sale right now, only for the month of april I think.
    Apr 2012
    WOW Thanks for the link. Good enough for me. Got a get one tomorrow.
