Results 1 to 13 of 18
Thread: SCROLLS
    Jan 2010
    SCROLLS
    is it possible for them to have suction but no discharge ?
    houston, texas
    I'd be thinking that's not possible.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    California
    I think.
    If there is a Black Hole located between the compressor and the discharge service valve
    Jan 2010
    What about the internal bypass ?
    Dec 2011
    New Zealand
    Quote Originally Posted by Phase Loss View Post
    I think.
    I think I know who stole my wife's "she who must be obeyed" Purse!!
    VTP99 GUILTY
    Dec 2011
    New Zealand
    If the relief valve is passing 100%, then any changes will occur within the compressor body, even though there still maybe compression at the scroll, If you are getting gas movement from the suction side external of the body, you must be getting gas flow through the discharge side external to the body, when running.
    Jan 2010
    Thumbs up
    Quote Originally Posted by barbar View Post
    Good point. I like your thinking. Now what if I said digital scroll with unloading ? Same answer right ?
    Dec 2011
    New Zealand
    When a digital scroll unloads, compression itself basically stops (with the relief valve compression still could be occurring), but you still have a pressure difference within the system. So flow will still continue even when unloaded for a short period.
    Jan 2010
    I do believe on unloading, the upper scroll lifts upward stopping all pumping action.
    florida
    Here's some info. http://www.hvacrinfo.com/cope_ae_bulletins/TAE1328.PDF
    Educational forums are open.
    houston, texas
    Thanks for that file cracker, I don't believe I've worked on a digital scroll before.
    florida
    Quote Originally Posted by Texas-Tech View Post
    Your welcome.
    California
    When you say no discharge. Do you mean 0#?
    or discharge is equal to suction?
