Results 1 to 13 of 13
    Jun 2006
    Model # for the Allstyle Coil: asfm6022a36evs r22 with TXV & AUX PAN
    I cant find any specs on the internet. Does anyone know whats the tonnage on this?
    Jan 2002
    Ft.Worth,Tx
    That coil will work on the condenser # that you listed .I was looking at ASFM60 and at 13.0 seer it will give you the rating.
    [Edited by aircooled53 on 06-17-2006 at 07:58 PM]
    'Life begins with the journey each day'
    Nov 2000
    Eastern PA
    There is no tonnage capacity of an indoor coil. That could be suitable for a 5 ton 10 SEER unit, 3 ton 13 SEER unit or 2 ton 16 SEER unit.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Jun 2006
    Im a bit confused. Will it work with my Carrier AC: 24ABR360A003310 Its a 5ton 13 seer.
    Nov 2000
    Eastern PA
    Don't know. Unless Carrier has rated it with that coil, no one knows.
    Nov 2000
    Eastern PA
    Looks like AllStyle Coil Co. has rated it;
    ARI Ref. # 943101
    Active
    CARRIER AIR CONDITIONING 24ABR360(A,G)32
    ALLSTYLE COIL CO., INC. Airstar, ThermalZone, TFC, Meridian, Haier ASF*6022A36E+D+V
    57,000 Btu
    13.00 SEER
    Are AllStyle coils made by Haier or are Haier coils made by AllStyle?
    Wierd rating. What do all those other companies have to do with a Carrier/Allstyle match? Look at ARI I guess that coil is also sold under the other brand names. Allstyle must make for Texas Furnace and Haier.
    Austin, TX
    Bald, it think you are right. I had to buy a few
    All Style coils, and paper work also said Tx Furnace,
    Meridian, so on.
    And the chart on the paper work, had listings of
    different btu's-seer ratings, by simply changing
    the check piston.
    Since Rheem could not get some of the evaps I needed,
    I had to get some All Styles, so far I have been
    happy with them. And it looks like I will have to
    get more. I don't know what is up with Rheem, but
    they can not get me any coils, except the new stuff.
    These All Style coils also said rated for 410a also,
    but I used them with R22. I am not sure I would
    want to use 410a in them, as they were rated for
    450 psi. Seems mighty tight on the high end.
    Jun 2006
    ARI Ref. # 943101
    Active
    57,000 Btu
    13.00 SEER
    So what's the story with these coils? Can you please send me the link to that info you just found? I searched on the net and no results.
    go to http://www.aridirectory.org and type in that ARI #
    Jun 2006
    So this is exactly what i have, even the carrier AC unit is the same, but what does it mean? Btu? Ari?
    ARI Ref. # 943101
    Active
    ALLSTYLE COIL CO., INC. Airstar, ThermalZone, TFC, Meridian, Haier ASF*6022A36E+D+V (Manufatured by AllStyle)
    cooling capacity: 57,000 Btu
    cooling: 13.00 SEER
    Nov 2000
    Eastern PA
    you can't expect to just waltz in here and have us tell you all of our secret codes and show you our secret handshakes!
    Geeez, some peoples children.
    Nov 2000
    Eastern PA
    Oh, all right;
    ARI is the organization that rates cooling and heat pump systems.
    The ARI information tells us that that model of Carrier unit has been ARI rated to be used with that model and after market manufacturer's coil.
    This does not mean that Carrier necessarily condons that match, but that the company that makes that coil has submitted a computer generated rating to ARI and ARI has accepted the rating.
