    Seatte Wa
    I was hoping one of you resi guys could give me the AC unit size to match up with a Trane TXC049C4HPCO thats the model off the coil,I think its a 4 ton unit based on the blower of the furnace.Thanks
    SW FL
    Thumbs up TRANE Heat Pump
    Originally posted by devildawg
    I was hoping one of you resi guys could give me the AC unit size to match up with a Trane TXC049C4HPCO thats the model off the coil, I think its a 4 ton unit based on the blower of the furnace.Thanks
    TXC 049 C 4 HP CO
    T= R-22
    XC = Cased Coil
    049= 49,000 BTUh ( 4 ton)
    C= Universal
    4= Accu-Tron Flow Control/Check Valve (FCCV)
    HP= Heat Pump
    C= Design Mod
    O= Parts Identifier
    Designer Dan
    Seatte Wa
    4 ton thank you sir
