Results 1 to 13 of 21
04-27-2012, 07:56 PM #1
Peoples Gas Opportunity or City of Chicago Job
After working for a low wage at a non union hvac company for about a year I am really looking into going union. I have been accepted for an opportunity to get 6 months of free training through a Veterans training program and enter Peoples Gas as a Utility worker. Only problem is that the 6 months is NOT PAID!! But with $24.00 per hour starting wage, pension, 401k and more, I think it will be worth the sacrifice.
Option 2 is a job as a construction laborer for the city of chicago working on a huge project replacing the entire water main system in the city. 2 year apprenticeship starting at $22 per hour topping out at $35 per hour+ pension, benefits and paid ojt.
I have 2 weeks to decide, any advice, ideas, or experiences with either?
04-27-2012, 08:00 PM #2
Well thanks a pantload buddy!!!!
04-27-2012, 08:02 PM #3
Member
- Jun 2003
- Virginia
- 376
If it were me, knowing what I know now, I would go for the union position. But that's also assuming you can get past that 6 month window without wages.
04-27-2012, 08:27 PM #4
- Apr 2012
- 17
Take the job with the Water Department.Hands down the best jobs going.Although you should find out how long[timeframe] the project is because you may be laid off upon completion.
04-27-2012, 08:58 PM #5
04-27-2012, 09:00 PM #6
04-27-2012, 09:01 PM #7
Member
- Jun 2003
- Virginia
- 376
Sounds like a toss-up then... Good luck with whatever choice you make...
04-27-2012, 09:24 PM #8
- Apr 2012
- 17
04-27-2012, 09:40 PM #9
Thanks guys, I'm leaning towards the City job myself just worried about what happens when the project ends, but hopefully there will be more work to be done.
04-29-2012, 09:17 AM #10
Professional Member*
- Dec 2004
- Chicago area
- 1,392
go for the gas company.
A laborer job will leave you totally clueless at the end of the project.
The only job you'll know how to do is lay pipe.
If you land the gig with the gas company, you can take that knowlegde and work anywhere.
04-29-2012, 01:27 PM #11
As a laborer I don't think you'd have the opportunity to learn much.
04-29-2012, 03:32 PM #12
with the public works dept wouldnt you learn to operate heavy equipment and such? i think you would learn much more than "laying pipe".
04-29-2012, 03:49 PM #13
- Dec 2004
- Chicago area
- 1,392
Not as a laborer he wouldn't. In order to run equipment, he'd need to be an equipment operator, which is a seperate union.
Chicago unions have a very "this is my job, and that is your job" sort of attitude.
He may not even be "qualified" to connect or disconnect the sections of pipe to the crane, because you'd need to be in the riggers union for that.
The way union labor sees it, you need at least 15 or so guys to install a furnace.
a trucker to deliver it, a rigger to get it off the truck, a laborer to bring it from the truck to the installing location, the rigger to unload the from the dolley to the point of installation, a pipe fitter to install the gas line, and electrician to run the condoit, a sheet metal worker to install the sheet metal, a service fitter to start up and test. I think I forgot the demo crew to remove the old one, etc...
I think you get the point.
