Thread: Air temperature
    Dallas,tx
    what normal temperature is supply and return, 15-20 F, please help
    It varies depending on humidity. But your 15 to 20 degrees, give or take a couple is pretty accurate.
    Dallas,tx
    if is more of 20 and below of 15 what is that? T/oyu
    If its more than twenty you could have airflow issues. If its less than fifteen you could have a refrigeration problem. But other factors such as high humidity can effect the temperature difference. Thats why when troubleshooting a system you have to take many different measurements to determine the problem ie superheat, subcooling, indoor temp, outdoor temp, gauge pressures etc.
    Dallas,tx
    Post
    tank very much for you help. You are good man.
