Results 1 to 11 of 11
    Oct 2011
    Commercial CU for Residential Application
    I would like to replace 10 standard residential CUs with 1 Mitsubishi City-Multi R-2 commercial CU on a residential application.
    It is a residential application with conditioned space of 10,000 sq ft.
    The power company has stated that we can change the residence to 3-phase power, and thus have the option to use the R-2 system.
    The perceived benefits would be increased space utilization and a simplified design. The perceived downside is backup in case of system failure and the issues of converting 3-phase power to single phase for equipment other than the mechanical system.
    Please let me know your comments.
    Southeastern Pa
    Quote Originally Posted by mwcasale View Post
    Are you a contractor, technician, or a builing owner?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Apr 2012
    lexington, NC
    Converting 3 phase to single phase will not be hard as long as it is a 208/230 volt power supply. All I can say about the City Multi is to be sure your are commisioned and certified to install and service the equipment. If not sign up for the class from your local dealer.
    Southeastern Pa
    Don't make duplicate posts.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2011
    MEP systems designer for an architect
    Merged threads.
    Chicago, IL
    Usually 3 phase comes with a SIGNIFICANTLY higher service/meter charge.
    Jun 2001
    Quote Originally Posted by craig1 View Post
    +1
    http://www.oge.com/residential-custo.../RateInfo.aspx
    To bad the S-series residential units don't come any larger than 48,000 btuh.
    2 or 3 of them would still be a cleaner install then 10 regular units.
    Southeastern Pa
    Well, 10 standard residential CUs would be feeding 10 standard indoor coils. I do not believe you can connect the Mitsu Multi to those coils.
    Now, can you design a system with the Multi condenser and 10 indoor heads? Sure. Anything else would be fraught with troubles, if you could get it to work at all.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
