Thread: a/c problem
    Feb 2012
    Whitmore Lake, Michigan
    a/c problem
    I have a packaged condensing unit on my mobile home for my a/c. Coming out of the unit I believe I have one big supply duct and one big return duct. I keep poping my fuses on the condenser, then I replace them and they will blow again a couple days later.what do you think could be the problem?
    Feb 2011
    Cloverdale,Ca
    Excessive amps.
    Living the dream !!
    Mar 2009
    Mount Holly, NC
    it's impossible to tell over the internet what is overloading the circuit.
    best thing to do is have a mechanical contractor investigate the problem.
    DON"T KEEP CHANGING THE FUSES!!! you will likely destroy the unit. best thing to do is have a tech check out the system. if the unit runs when you change the fuses, the repair should not be massive.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Athens, Ohio
    Quote Originally Posted by mikeybow View Post
    Move to AOP?
    Agree. Looks suspiciously like DIY.
    Moved to AOP Residential. Only vetted pro members are allowed to respond here.
