Results 1 to 13 of 26
Thread: Scroll or TXV
    Jan 2010
    Scroll or TXV
    Lennox RTU M# GCS16-090-200-2Y
    #1 Compressor going straight into deep vacuum and high side sitting @ 100PSIG
    #1 circuit holds 6 pds. Added 2 pds with no change in high side pressure
    #1 circuit TXV frosted up as well as the distributor and cap tubes.
    Compressor pulling low amps. Shutting down on thermal overload.
    I'm thinking the compressor is not pumping but it sure is sucking
    Soooooooooo is it the compressor or a restricted TXV ?
    If restricted why not high head pressure ? Would it act as a pump down ( nothing in so nothing out ) Also how would a scroll compressor pump down but not pump ?
    What a DAY
    Guess I'm going back with both.
    In a machine room
    You have compression ratio of 7 to 1, I doubt the compressor is the problem.
    It's not uncommon for high side pressure to be low when you have a liquid line or metering device restriction.
    Worry is a really gross misuse of one's imagination. -- PHM
    Jan 2010
    Yes but I added 33% of the charge. Don't you think that would add some head pressure ? I even bleed some high side over to the low side and still no rise in head pressure. Also the compressor is getting hot at the top with no load and low head.
    Apr 2012
    lexington, NC
    Are you checking the head pressure at liquid port or discharge gas port?
    In a machine room
    The top of the comp should get hot with no Refrigerant flow.
    I would replace the txv first if that is where the frost starts.
    Please don't replace both at once! Then we won't be any smarter!
    Dec 2011
    New Zealand
    Compressor is OK.
    It maybe as simple you do not have enough charge!
    and yes you could have a restriction, and it could be the TXV.
    Turn it on just for a few seconds, start to draw a low pressure. Turn off, does the pressure rise very slowly or fairly fast.
    Jan 2010
    Quote Originally Posted by Jpaulsmith View Post
    Discharge gas port.
    Jan 2010
    Quote Originally Posted by chuckcrj View Post
    I here ya.....I would do the lesser of the two evils first. Actually I would lean towards the power element being dead.
    Jan 2010
    Quote Originally Posted by barbar View Post
    Compressor is OK.
    Hello down under ,
    Lived 9 months in New Zealand. Great country !
    Compressor goes right to a deep vac. When I shut it down
    it does rise faster then the #2 compressor.
    Apr 2012
    lexington, NC
    I think its odd that the head pressure doesn't rise over 100psi but stranger things have happen. TXV sounds like the fix, but what do I know I'm just a dumb noob to the site. lol
    Dec 2011
    New Zealand
    Hello down under ,
    I hope you missed the shakes!
    I would suggest that you just need to add refrigerant.
    Your TXV is designed to pass liquid, and it is passing mainly vapour, with a tad of liquid, hence the heavy frost! And not enough refrigerant to fill the cond.
    Jan 2010
    [QUOTE=Jpaulsmith;13072801 but what do I know I'm just a dumb noob to the site. lol[/QUOTE]
    No such thing as a dumb noob (your a work in progress)
    Jan 2010
    No shakes but lots of sheilas ! Spell check couldn't help me here. Loved that Wellington harbor. Both islands are beautiful and no crime a big plus
