Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    Sep 2006
    Dallas Tx
    i had the same problem on a few 30 ton aaon units... found the problem to be peanut relay #2...... that relay sends power to the condenser coil, which was chattering or sticking... god help those aaon units
  2. #28
    Aug 2008
    Athens, GA
    What was the outcome? I have multiple stores with various sizes of these things with severel configurations. One thing in common. If its hot inside or in a area, discharge is tripped. With no rhyme or reason. And I'm to logical to believe that.
  3. #29
    Nov 2011
    GA
    open run capacitor causing one of the motors to run backwards?? if their single ph motors. ive seen it on a 40 ton voyager before causing the unit to lock out
    (((PEACE IS THAT BRIEF MOMENT IN HISTORY WHERE EVERYBODY STANDS AROUND RELOADING)))
  4. #30
    Nov 2011
    GA
    Quote Originally Posted by zw17 View Post
    Out of ANY units I have ever dealt with AAON units are by far the hardest coils to wash and keep clean.
    I have run into this exact issue. It took a fire hose to get those extra thick coils cleaned out properly and I was amazed at the ammount of dirt that we got out compared to a regular garden hose and pressure washer.
    I would bet a paycheck that your coils are plugged in the center. They may look clean, it's very deceiving.
    How did you get a fire hose hooked up. That is exactly what i need on a job with 3 30 ton condensers
  5. #31
    Nov 2011
    GA
    Dang didnt realize this tread was so old
