Results 1 to 13 of 25
    Apr 2012
    Some random installs
    Just got alot of pics on the computer from my phone so thought id share! opinions appreciated
    Chicago, IL
    Your sheet metal work is beautiful. I would have done something about that head-banger gas line in pic 4 though.
    Apr 2012
    I understand. Not trying to make excuses but i didnt have any 1'' stuff on the truck and we moved the furnace 4'. The job was an hour away and i overlooked it the second day there. The homeowner was very happy so i left it. Thanks for the compliment though! Were also not equipped with oddball gas fittings and such due to the fact that we are primarily change out. We have four crews and we crank out 2 full systems a day with each crew!
    Mar 2011
    Nice work, looks great
    Jun 2010
    Western Nebraska
    Installs look nice! I don't like the condensate drain on the last pic though. If the 3/4 PVC plugs at the bottom during AC season you will fill the HX on the furnace full of water.
    Great sheetmetal work.
    Apr 2012
    I didnt think it would be an issue with just a few feet of pvc. Did a few like that and learned the hard way so now i tie the a/c in below the trap
    Jul 2009
    Columbia, MD
    with your boiler;
    - pumping into expansion tank...not good.
    - pump is on return side...should be on supply and pumping away from expansion tank
    - exhaust pipe slopes down hill then back up
    - get rid of the bell draft diverter and install a tee with a 6" barometric damper and a spill switch. also perform a combustion analysis.
    Apr 2012
    As far as the pump/tank, supply /return thing, i should call the boiler manufacturer and tell them their install instructions are wrong. Been doing this 14 years and the majority of companies specify it be done that way. The bell diverter comes with the boiler as does a safety switch. Kinda got me on the flue thing but had no choice and it vents fine. Also, I did that boiler and a furnace/coil that day so it came out pretty good considering
    Oct 2005
    Indianapolis, IN
    Quote Originally Posted by orangesummer View Post
    Great looking installs! Doing a boiler and a furnace/coil is a ton of work for one
    day... there is no way I could pull that off! I have put quite a few boilers in just
    like that pumping the return at the exp tank just like that. Some worked fine and
    some not so much. I did it that way because everyone said thats how you do it.
    Anyway, check out Dan's book Pumping Away. Once I tried out piping a boiler
    like Gravity said I couldn't believe the difference.
    Apr 2012
    I tend to do what the manufacturer reccommends due to some bullcrap warranty issues in the past.(this part was installed not the way WE recommend so no warranty for you and this customer)BUT Lennox boilers (dunkirk) do it the opposite?? Ive had alot less troubles going this route. And yes it was a rough day! Ill definitely check that out though. Thanks!
    Jul 2009
    Columbia, MD
    i have never had a manufacturer deny me warranty because of the way something was installed. also you say the boiler vents fine? did you verify this with a combustion analyzer?
    Jan 2010
    Toronto,Ontario Canada
    Ya i think the vent is a little odd and shouldnt be like that. Is the chimney already b vented? thats why a new one wasnt put in?
    Get er Done!
    Do what has to be done
    when it has to be done
    as well as it has to be done
    And doing it all the time.
    Jan 2010
    Ya i think the vent is a little odd and shouldnt be like that. 2 recent new appliances connected into a chimney, ummm i would have insisted on putting in a new liner.
    Get er Done!
