Page 3 of 3 FirstFirst 123
Results 27 to 30 of 30
  1. #27
    Dec 2011
    Kansas City
    You may have a restriction between your condenser and the sightglass. Clogged drier, maybe?
  2. #28
    Aug 2009
    Jurupa Valley, CA
    Quote Originally Posted by Perennial Student View Post
    It's spelled Cyclus... pay attention...
  3. #29
    Mar 2012
    High head - might be caused by non-condensables.. Lack of air flow/heat transfer at condenser.. If TXV is either open- suction would be high and head low, closed- suction low and head low.. If you have the wrong refrigerant or mixed refrigerant it could cause head press problems as well as other problems..
  4. #30
    Jun 2008
    Rochester, NY
    Wow...there are so many variables that can cause a high head pressure and we don't have any details on what's going on. Plugged condenser coil, bad condenser fan motor, fan cycle control, headmaster, is it a water cooled condenser? What type of refrigerant? Non condensables in the system. Mixed refrigerants. Refrigerant restriction. Many other things can be listed and it can be multiple issues at the same time. Way too many variables and this isnt a diy site. Sounds like its time to call in a pro and have it diagnosed and fixed properly before you hurt yourself or seriously damage your equipment.
