Results 1 to 13 of 30
    Apr 2012
    High side pressure higher than normal...
    Hello everyone, I'm very new to this site but a couple of friends told me this forum will help out alot.
    Currently I have a walk in freezer that is giving me a headache.
    When the compressor is running the cyclus (the thing that shows how much gas is being pumped) shows that it should be filled up with more gas. Problem is when I install the gauge onto the compressor. High side would come up to 300-350... when it should only be 200-250.
    I can't get a grip on where the problem is.
    I figured it might be the TXV not working correctly... but I wanted more opinions.
    Thank You
    The Hot South
    You need to call a pro.
    East of big city prices.
    Is it dirty?
    how do you know it should be 200-250? ... WTF is a cyclus ?
    Quote Originally Posted by hvac wiz 79 View Post
    The "cyclus" is also referred to as a sight glass among us non predictive text user in this world.
    Apr 2012
    there are 2 other ac units that are the same and they are 200-250.
    for the high side, pressure should never exceed 300.
    .... seriously? its pretty much a window that shows you how much gas is running in the system. shows you if its low, empty or full without having to put in your gauge..
    Apr 2012
    Quote Originally Posted by thegoodlistener View Post
    Is it dirty?
    is what dirty? the filter? No i just replaced it, the coil isnt dirty. this is a strong working ac unit..
    Quote Originally Posted by aaronkim92 View Post
    I suggest a great running log with temps and pressures to post . More information gets you better answers than guesses. Someone posted on this site one time the phrase " no science no solutions". HVAC problems enters the world of science more often than not.
    Oct 2011
    Chicagoland Area
    how'd you get a pic of my soon to be mother in law?
    there omare 2 other ac units that are the same and they are 200-250.
    ohh a window that shows you how much gas is running ... so its like a level indicator? ... so what happens if i don't see any gas?
    Oct 2011
    Chicagoland Area
    Means your out. Go to the gas station and fill 'er up.
    Oct 2011
    Chicagoland Area
    Why would you compare what a freezer is doing to what an a/c does? What will happen if pressure exceeds 300?
