Results 1 to 13 of 16
    Jun 2006
    The indoor humidity in my air conditioned home as risen recently. I'm in a very dry climate (outdoor humidity in Southern AZ is about 5% right now) but noticed over the past couple of days the indoor humidity rising. Could this be caused by HVAC condenser/evaporator problems?
    Thanks!
    If your air conditoining is maintaining the proper temperature in your house its probably working fine. The only problem could be if the unit is oversized it might not remove the humidity fast enough. Try lowering your thermostat a little and see if that helps.
    Unhappy
    Do you need relative humidity lower than that?
    http://www.air-conditioner-selection...er-sizing.html
    Jun 2006
    The unit is cooling the house fine and not running any longer than it used to. The indoor humidity is a comfortable 35%, but it never used to get that high. I was just wondering if it’s normal for an HVAC system to put that much more moisture into the air.
    Thanks!
    Cooling system have no way to add moisture to the air. They normally remove moisture, but in and of themselves can not add what is not already there. In other words they can not make water. They can distribute moisture from other sources, maybe a shower fan not working, clothes dryer not venting, stopped up drain line etc. If you have a humidifier on your system, sounds like you should, maybe it is stuck on.
    If all else fails....Try reading the directions!
    Tell it like it is and let the chips fall where they may.
    Any views or opinions stated here are strictly my own.
    Madison, WI/Cape Coral, FL
    Adults add .25 lbs./person of moisture per hour. One lb. of water raises the %RH in 1,000 sqft, of space 8%RH. Your outside dewpoint is 27^F. At 75^F inside, 27^F dp = 25%RH. Add a little inside moisture and you will have 35%RH. Appears normal to me. Let me make this clear. A dehumidifier will not help. Now that was not so hard to say. TB
    Do you have your fan on continuously. If so the the moisture from the coil could be blowing back into the house in the off cycle.
    Before you criticize someone, walk a mile in their shoes...that way you are a mile from them and have their shoes
    Just at a home the other day similar scenario.
    Didn't know what was adding humidity.
    A 50 gallon fish tank was the culprit.
    Jun 2006
    Thanks for the replies! We don't run the fan continuously and haven’t recently added any obvious sources of moisture. Another mystery of desert perhaps...
    Did you change the usage duration of the AC unit?
    Do you have a humidifier?
    35% RH I would not worry about that!!!
    Oct 2002
    Mahopac NY
    Ditto.
    Dogs truly are man's best friend!!
    When did you have it serviced last.
    If the indoor coil is getting dirty, then it may not be removing as moisture as it use to.
