Page 3 of 3 FirstFirst 123
Results 27 to 39 of 39
Thread: Vacuum setup
  1. #27
    Dec 2011
    louisiana
    Thanks to all you guys that took the time to post your setups! Mine is just like JTCHVAC, except I need to put a blank off valve on the pump. I do however wonder about the tightness of all the CRT's and blank off valve. I know I had a cheaper CRT once that I originally bought to change bad cores on pressurerised systems that I know would not hold a 500 micron vacuum. let alone 300 which I really like to pull to. May try AIRESEARCH idea without CRT, but where do you put micron gauge (I guess a tee in line but another leak point?)
  2. #28
    Nov 2010
    N. Idaho
    I'll be switching mine up a bit. Will post when I get more chances to do so
    "I've got my Gas Mechanics license"
    "Yea, well my 16yr old daughter has her drivers license, doesn't mean she knows how to drive"
  3. #29
    Mar 2011
    East Coast FL
    The carpenter , You could install the micron gauge near the equipment with a brass tee and a short hose or coupler.
    If you keep up with the gaskets in your hoses and snug everything down , the setup is capable of holding less than 200 microns.
    That is without any type of sealant.
  4. #30
    State College, PA
    Quote Originally Posted by thecarpenter View Post
    Appion CRT is rated at 20 microns. This also gives you a port for your micron gauge.
    HTH
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://icemeister.net/aop_map.html
  5. #31
    Akron
    We get a lot of questions on the how to and what do I need to perform a proper evacuation. I put together this piece to better explain the process and the tools required.
    http://www.trutechtools.com/Vacuum-Training_c_1100.html
    JLB- Co Owner TruTech Tools Inc.
  6. #32
    State College, PA
    Thank You !
    Quote Originally Posted by jim bergmann View Post
    Very nice description.
  7. #33
    Nov 2010
    N. Idaho
    I get about 5 sec. of that link before it goes to the Categories. I'm using an iPhone. What's up with that?
  8. #34
    Dec 2003
    I just watch some Yellow Jacket videos and they use their crt when using their vacuum setup
  9. #35
    Nov 2010
    N. Idaho
    Quote Originally Posted by mh heating View Post
    I haven't actually seen the appoin in person. I'd like to know what construction is different than YJ. I have no problem pulling well below 500, heck just last Thursday I pulled down to 180 or so.
  10. #36
    Akron
    Quote Originally Posted by Damien View Post
    It is detecting your i phone browser and going to a I phone friendly version of our site. You can shut that off at the bottom of the page, or navigate there through the categories. It is under vacuum, vacuum training.
  11. #37
    State College, PA
    The only difference that I know of is that it has double "O" rings. Seems to make a better seal. I have my YJ & also 2 Appion CRT's I feel more confident with the Appion than I do the YJ.
    Sometime just doing what makes you feel is the best job is what it takes.
    I have not tried to pull a vacuum with my YJ in a few years. They may work, they may not. But Appion is actually rated for 20 microns. I have yet to see where YJ will state what their CRT is rated for (in microns).
    So- OK it just gives me that warm fuzzy feeling to use the Appion.
    Hope that answers your question.
  12. #38
    Nov 2010
    N. Idaho
    Just not sure what double o-rings means. Where do they seat on the flared fittings?
  13. #39
    Nov 2012
    Macomb Twp MI
    Those appion crt's are the cats pajamas
