Results 1 to 13 of 39
Thread: Vacuum setup
    Nov 2010
    N. Idaho
    Vacuum setup
    Looking for opinions or different ideasAttachment 258821
    "I've got my Gas Mechanics license"
    "Yea, well my 16yr old daughter has her drivers license, doesn't mean she knows how to drive"
    Apr 2012
    Chicago, IL
    looks good to me, but who knows. You could add a fancy micron gauge if you want. Or also use a core extractor tool to pull the vac with no schrader core and then reinsert it after evacuation.
    Damien, could you take a close up picture of the adapter you are using on the pump to attach your 3/8 hoses?
    Nov 2010
    N. Idaho
    The fitting on my pump is 1/2flare x 1/2flare x 1/2npt
    In a machine room
    You are not gaining much by pulling the schrader cores in the system since you are still pulling through the cores in your core tools.
    You will pull vac faster if you pull straight through the core tools, so you would have a straight wide open shot into the system.
    Apr 2012
    Chicago, IL
    Most core tools have an auxiliary vacuum port, that you can also pull the core from, seal off, and then return the system core when done evacuating. I don't know about all the fittings that he's using here, but with a standard set of hoses that have just a core depressor, removing the schrader cores in the system is wide open, like opening a refrigeration service valve. Seems to speed up recovery a lot. And makes for a better vacuum, so I've been taught.
    In a machine room
    Quote Originally Posted by jw-lu597 View Post
    Really? I haven't found this to be true, particularly when recovering. I don't know about all the fittings that he's using here, but with a standard set of hoses that have just a core depressor, removing the schrader cores in the system is wide open, like opening a refrigeration service valve. Seems to speed up recovery a lot. And makes for a better vacuum, so I've been taught.
    Yes, it does speed up recovery, but not the way it is hooked up in the pic. He is pulling through the cores in the core removal tool (CRT).
    If Damien takes switches the mic gauge to the other port and hooks his vacuum hoses directly to the end of the CRT, he will speed up vac and recovery times.
    Also why use 3 CRT's??
    Apr 2012
    Chicago, IL
    I see -- was confused with what you were saying for a second. We're on the same page. That's a lot of adapters. The less connections and restrictions the better.
    Nov 2010
    N. Idaho
    I removed all schraeders including in the CRTs. I use three for my micron gauge. And nylog on all those connections. Should have gotten a different angle
    In a machine room
    Like this.
    Nov 2010
    N. Idaho
    I'll try just two CRTs on the next job. I agree, less connections the better.
    Try explaining this to mfrs, Lennox, that do not allow the use of CRTs on most resi equip!!!! http://hvac-talk.com/vbb/images/smilies/gah.gif
    Nov 2010
    N. Idaho
    What do you do about those RTU's that have the longer schraeders?
    Just braze in regular service ports?
