Thread: tube plugs
    pennsylvania
    tube plugs
    Used my first two piece tube plug today. I have always used just the plug in the past with good success. Any thoughts on the two piece would be appreciated.
    Ohio
    A lot less to screw up with the two piece vs the solid. Better grip IMO.
    Easy as pie wasn't it?
    Feb 2012
    utah
    just make sure you have the exact size and they work fine.
    Windsor ON Canada
    Need to have the end of the tube faced flush with the tube sheet so that the shoulder of the plug seats properly. Have used both and prefer the two piece.
    May 2011
    Gateway to the west
    Tube plugs
    I have been using the 2 piece plug for over 25 yrs, have not had a
    problem with one yet. Just make sure the center pin is the right one for the plug. Just plugged 6 tubes in a York generator last week.
