Thread: Geothermal Outlet Temp?
06-12-2006, 10:40 PM #1
- Jun 2006
- 3
Can anyone tell me what the outlet temperature should be when using the AC and a closed loop geothermal system? Is it the same as for a regular AC?? My understanding is for a regular system it should be about 20 deg cooler than the room temp?
06-12-2006, 11:15 PM #2
- Jun 2006
- 3
bump....... any help?
06-12-2006, 11:42 PM #3
Professional Member*
- Feb 2006
- 468
20 might be a good number but...
...there are a whole bunch of other variables.
Assuming you checked / changed the air handler's air filter and you still have inadequate cooling or some other issue its time to call a pro to check the system in person.
