    Jun 2006
    I need my 2-ton heat pump and air handler replaced as my current system is 20+ years old.
    I'm trying to decide between a 10 Seer Gibson system and a 13 Seer Ruud/Rheem system.
    The difference in cost is ~800.
    This is for a condo that I plan to hold onto for around another 3 years.
    Any opinions on Gibson vs Ruud/Rheem?
    Also I don't know a lot about these systems and one contractor mentioned getting a new float switch, drain pan and cleaning the refrigerant lines. Is this something that is done on a standard system replacement or do I need to be specific that I want it done?.
    Thanks in advance.
    Washington
    I would replace the refrigerant lines, but I'm just over-cautious that way.
    Some times in condos you can't replace the line set, without an act of congress, so yes, flushing the lines is a good idea, but not a standard thing on unit change outs.
    Gibson, is Nordynes builders grade unit.
    Which one?
    Higher efficiency rating if you're a heavy user.
    Lower efficiency rating if you're an occasional user.
    Here's a description page:
    http://www.air-conditioner-selection...ing-guide.html
    All the best!
    Jun 2006
    Thanks for the replies.
    I'm going with the Ruud/Rheem b/c of the efficiency and it has a 10yr warranty on the compressor while the Gibson only has a 5yr. Just in case I end up staying longer than planned.
