    Jul 2003
    lvl ky
    Question
    What (if any) is the best way to check a contactor, other than visual. I read one time that some techs test resistance across the contacts, anyone do this? I know about obvious signs, like chattering, and buzzing. Thanks.
    Jun 2006
    Checking resistance sounds ok, not that I know HVAC, but replacing suspect parts may be better use of your time.
    Huntsville,AL
    it takes a Wheatstone bridge -- very l o w resistance! forget it.
    While energized, a voltage test across same leg terminals.
