    Sep 2006
    electrical complexity: hot vs cold
    Is their any arguement that hot side is more challenging,electrically speaking?
    NE Alabama
    "IF" you understand electrical circuitry then electrically speaking there is no difference. Only by following the path do you reach the correct conclusion and the end. The hard part of cold side is the refrigerant cycle. I don't understand why there would be any difference "electrically speaking". Electricity doesn't care what the temperature is.
    Oct 2011
    Chicagoland Area
    Wires, switches, and loads. If you understand how a piece of equipment works, you can figure out what's wrong with it.
    Apr 2012
    Jackson, MS
    No there's not any question, hot side has become come a lot more technical related with controllers and combis coming into the market, whereas most refrigeration, in the food business, has stayed relatively the same.
    NE Alabama
    Smile
    Sounds as if someone hasn't tackled a Traulsen blast chiller yet.
