Thread: WATERFURNACE VIBRATION
06-12-2006, 01:04 PM #1
- Jun 2006
- 6
Ive got two 12 year old Premieres in my house, both verticle mount sitting in the attic. I cant seem to stop the vibration the compressors put out. They resonate the walls, etc. Its just annoying. Ive tried several different pads to stop it but to no avail.... any suggestions... can I hang them from the rafters??
06-12-2006, 04:38 PM #2
- Nov 2005
- PortChester N.Y.
- 135
Do you mean water cooled heat pumps?????
06-12-2006, 04:42 PM #3
- Jun 2006
- 6
geothermal units with closed loop
06-12-2006, 05:08 PM #4
- Nov 2005
- PortChester N.Y.
- 135
We usually set water cooled units on Pumpup's then foam blocks with rubber pads underneath the unit between the pan and blocks. It sounds like you are going to need an expeirenced company to solve your problem.
06-12-2006, 10:35 PM #5
- Jun 2006
- 3
vibration/noise
I got some rubber dampers/isolators and hung mine from the rafters..... it has helped.
