Results 1 to 2 of 2
    Enthalpy conversion btu/lb to kj/kg
    Can someone explain the conversion of enthalpy from btu/lb to kj/kg?
    Every website I search says to multiply by 2.326, but when I do some checks (using web based calculator or psychrometric charts) the results do not work.
    For example;
    77F, 50%RH = 29.3 btu/lb
    25C (i.e. 77F) 50%RH= 50.29 kj/kg
    and 29.3 x 2.326 <> 50.29!
    I am using an Alerton system which has an Enthalpy block which only supports F and btu/lb and I am working in SI (metric) units.
    San Diego, CA
    1 Btu/lb = 2.326 kJ/kg
    http://www.engineeringtoolbox.com/un..._per_unit_mass
    Not sure where you're getting 50.29 from.
