Results 1 to 7 of 7
    Jun 2001
    Wire Nut Connections for Furnaces?
    What's up with certain brands of HVAC units using wire nuts to hook up to the thermostat wires instead of hooking directly to the board? The board was behind the flue/blower compartment door. Seems like a PITA design, is there any advantage to doing things this way?
    Mar 2009
    Mount Holly, NC
    yes.
    the manufacturers don't have to build a box to separate the tstat wire from the high voltage wire...
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    Jun 2001
    Another gripe with these units is the way the panels attach. Who thought of using little plastic square "rivets" to hold the panels on? What can't they just slide up like everybody else?
    Cincinnati, Oh
    Sounds like your talking about goodman? If so, here's why:
    ARUF/AEPF air handlers provide a bundle to wirenut to. This is due to thermostat wire not rated to be inside the electrical enclosure of the air handler.
    Now, the new AVPTC air handlers, for WHATEVER reason, thermostat wire can be ran inside the enclosure. No idea why, especially since thermostat still isn't rated to be in the same "box" (or enclosure) as high voltage. Yet, it still is.
    We've been mounting a 4x4 box where the low voltage wiring on ARUF/AEPF comes out, and putting our wiring inside the box.
    "Just get it done son."
    Dad adjusted
    Jun 2001
    At least I now know why, but it doesn't make it any less of a PITA to wire them up..
    Dec 2011
    bedford ind
    I think nordyne dos something like that.
    Cincinnati, Oh
    Quote Originally Posted by 54regcab View Post
    Yeah, I prefer the terminals myself.
    Dad adjusted
