Results 1 to 11 of 11
    Jan 2010
    Sacramento, CA
    Frown System full of water and dirt
    I have a water cooled packaged unit that the condenser failed and sucked condenser water into the refrigeration circut. Any ideas what I should use to flush the system out? It is really dirty.
    Apr 2012
    Louisiana
    What tonnage unit? We almost always replace the unit when that happens. What repairs are planned? Compressor changeout? Replacing condenser? Is it a scroll? What refrigerant poe oils a pain.
    Jan 2010
    Sacramento, CA
    It is 120 ton with 4 thirty ton Copeland scrolls. We replaced the condenser coils now need to flush the system. The new stuff on the market doesn't work.
    Apr 2012
    Louisiana
    I'm sure others know more to do, but blow with nitrogen evacuate and install new drier. Run unit and Keep changing oil and drier until clean.
    Ohio
    Get your post count up and apply for pro membership. This is not a DIY site and we cannot assist you with any repairs until your credentials are proven.
    I can tell you are going to need some help on this one so hire an experienced tech.
    Nov 2007
    Mississippi
    Pull dip tube out of a recovery tank and put it in series between vacuum pump and ac unit. Tank should act as an accumulator for the water. A lot less changing of the vac pump oil. Also evacuate with micron guage down to 500 microns if mineral oil/ 250 if it is POE.
    Apr 2012
    winnipeg
    oh man trouble..... not gonna be fast ..... could take a month ...
    Sep 2006
    River Forest IL
    The unit wouldn't happen to be a McQuay, would it?
    Oct 2001
    suction line dryer with ball valves and a shraddrer port on the cap to revac...protect those scrolls taking you have 2 compressors per suction circuit...
    "when in doubt...jump it out" http://www.youtube.com/watch?v=U1qEZHhJubY
    Jun 2009
    i just went through this lost a heat exchanger...
    did the system run when failure happen water get in to txv oil etc??
    I had a system do fouled up couldnt even get refrigerant out with recovery machine schraeder cores froze plugged up with wax.
    All that water and oil will turn into the nastiest thickest wax.
    If they insist on repairing this is against epa but the only way you will even get this thing a chance is to run r11 through this machine open up all circiuts on coils etc and flush flush nitro r11 nitro after probably a month of vacuum pumps when you think it is even close. jmo
    Oct 2011
    La.
    Call hudson or whoever is your refrigerant player in your town. They can come to your site and flush the unit and remove water from the system. Faster than the alternative, but it does cost.
