+ Reply to Thread
Results 1 to 16 of 16
Thread: Upgrade Insight 3.6
    Nov 2009
    Upgrade Insight 3.6
    Dear All,
    Anyone can advise me how upgrade insight 3.6 to 3.11 advance server?
    After I installed insight 3.11, I restore insight 3.6 database. after restore,
    I cannot open Insight 3.11. It came out with a message "Access to Insight Denied due to insufficient privilege. please check with your account administrator".
    Please note that 3.6 workstation is work group (win xp) and 3.11 workstation is domain control.
    Your Kind Assistant is highly appreciate.
    Apr 2005
    Montreal
    You need a new license code to unlock 3.11 matching your dongle key SN#.
    Southeastern Pennsylvania, Delaware, Maryland
    First, You need a license to unlock 3.11. Also you can not upgrade more than 2 revisions at a time. You will need to go 3.8, 3.10, 3.11. Sorry
    Mar 2012
    San Francisco, CA
    WillyTech is absolutely correct. It might be inconvenient, but it is the only way to guarantee a complete upgrade.
    Removed Link. You need to be a Pro Member in order add a link to your company. Please take a minute and review the sites rules.
    Nov 2009
    Dear All,
    I have complete the upgrade from insight 3.6 to 3.11 follow your instruction by upgrade every 2 version.
    But after upgrade, all points displayed on graphic is failed every 1 or 2 seconds.
    if we check inside Alarm Status page there is no controller failed. and also the network is working well. if we look those points from CT, it is normal.
    Currently there are 2 versions of controller 2.6 and 2.85. Would it be the problem of version conflict between Insight 3.11 and controller version 2.6?
    Thank for your advice!
    Mar 2012
    San Francisco, CA
    sorry it took so long to get back to you.
    Check APbacklog.txt (a file in Insight/Database) in an application like Notepad++, for any occurrences of the word "error". At the end of each section, the total errors will be aggregated. If a section has errors, that section of revision must be reperformed. Also, I remember something about an issue in updating 3.6 to 3.7. You might want to get your Siemens tech to look it up for you.
    Mount Airy, MD
    Arpoc926,
    I have removed your Link to your business/employer . You need to be a Pro Member in order add a link to your signature. Please take a minute and review the sites rules.
    Thank you in advance !!
    Nov 2009
    Quote Originally Posted by Arpoc926 View Post
    I checked APbacklog.txt follow your comment. there is no any error in this file.
    Could you please advise the solution?
    Mar 2012
    San Francisco, CA
    If there are no errors in APbacklog.txt then it may be an issue with revising from 3.6 to 3.7, which I am pretty confident there is a Field Support News article about. I also recall problems with graphics on 3.11 prior to installation of service pack 1. Have you checked to ensure all your services are running correctly?
    There are no conflicts with insight 3.11 and any Apogee firmware. I would recommend restoring the database. Other than that call your Local branch
    Nov 2009
    I restore from 3.6 to 3.8 then from 3.8 to 3.10 after that from 3.10 to 3.11.
    it was working normal after installation but after install about 2 weeks it become like this.
    Mar 2012
    San Francisco, CA
    There are indeed no conflicts specific to Insight 3.11. If you have taken WillyTech's advice, and restored your DB, then it is indeed time to call your branch. Any further troubleshooting would require quite a bit more knowledge about (or access to) your site.
    Oct 2007
    Arizona DUH
    If you have online comm tools you can upgrade skipping versions. Our local branch did it fairly quick and restored the database, it was worth the money spent getting them onsite.
  14. #14
    Nov 2009
    Quote Originally Posted by phoenixfitter View Post
    I am using CT rev 3.9. could you please advise how to upgrade using COMM TOOL?
    Thank
  15. #15
    How do you have com tools? Am I missing
    something?
  16. #16
    Apr 2005
    Montreal
    I agree with WillyTech. Comm Tools is a proprietary software for Siemens tech. Having to ask how to update job database with it leaves me puzzled. This is one of the basic things you should have been showed before using that tool. Lack of training from Siemens, unless your software is of doubtful origin...
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
