Results 1 to 10 of 10
    Apr 2012
    Bryant or American Standard
    House is 2450 Sqft and am about to replace system.
    Now looking at the following:
    Bryant
    Model 315 Plus 80v Gas Furnace pn315AAV048090 with the Model 226A Heat Pumppn ANA036.
    Am Std
    Platinum SV Freedom 80 furnace pn Add2B060A9V3VA and Platinum ZM Heritage 20 pn 4A6H6036E1000A heat pump.
    Thoughts and comments welcome, espicially if you can tell me which might be the better system.
    SW FL
    Hmm Locale
    Quote Originally Posted by Roylance View Post
    Bryant
    Am Std
    I guess they are just about equal for a Georgian.
    Designer Dan
    4A6H6036 is not a Heritage 20. It's the "16 SEER" with the unloading scroll compressor.
    Apr 2012
    You are probably correct, it is listed in the quote as a 16 SEER 2 stage heat pump.
    So bryant or american standard?
    Apr 2012
    Changes
    Dealer just came back and said they would give me a 286B instead of the 226A at same cost with the evolution thermostat. THoughts & comments welcome.
    Mar 2006
    The South
    Roylance
    Questions.
    What is your location?
    What mdl evap coil quoted for each system? Makes a difference as far as performance/efficiency numbers.
    New linesets included?
    Evolution thermostat included with Bryant quote? What thermostat with AmStd system?
    You will note the AmStd furnace quoted is smaller. Probably should be the 80
    KBTU model.
    What about a filter media cabinet?
    Depending on your location, I would not want a HP without electronic demand defrost.
    What size furnace and AC are you replacing.
    Post back.
    IMO
    Apr 2012
    Arrow
    I've decided to go with Bryant but will not sign anything til tomorrow.
    Questions.
    Sammamish Washington, just east of Seattle.
    No idea but will find out tomorrow.
    Yes, it is now with Bryant.
    Pro 8000
    KBTU model.
    I thought it was low also but he indicated that he had done a measurement.
    4" media filter, not named.
    Not sure if it is needed, we only get snow 2 or 3 times a year and it generally stays in the mid to low 30's from mid Dec to mid Feb.
    95K BTU Carrier and a 4 ton Trane AC, both over 14 years old.
    Post back.
    Thanks for any insight.
    SW FL
    Does this apply ?
    http://pse.com/savingsandenergycente...mp-Rebate.aspx
    If yes, make sure you have the proper documentation in order to fully qualify.
    Designer Dan
    Mar 2006
    The South
    Roylance
    Yes or no?
    Evolution thermostat is included with Bryant quote?
    If not, it should be!
    IMO
    Apr 2012
    Dan SW FL,
    Yes, it applies, also Bryant special of $1000 if installed by end of month.
    Tigerdunes,
    Yes evolution thermostat was included.
