Results 1 to 13 of 14
    Feb 2012
    Toronto Canada
    Need cheap 2 ton ductless with 140ft lineset run
    I need to find a cheap ductless 2 ton and lineset needs to be able to run 140ft I'm talking goodman not mitushubishi hear customer is cheap what product would you guys recommend I offer and install?
    Jul 2001
    Anderson,SC
    GREE
    Feb 2012
    Toronto Canada
    What's that?
    Feb 2012
    Toronto Canada
    Does anyone know of a ductless that can have lineset runs over 140 ft comfortstar says 100 ft and goodman is 50ft I need 140ft min can't find a ductless except mitubushi which customer is against.
    What product do you guys say I use??
    I don't think you will find a "cheap" system that will work properly with long refrigerant lines.
    I believe you will need something like a Daikin Sky Air, or other manufacturers equivalent.
    The Sky Air allows refrigerant line lengths of up to 230', and a vertical separation of up to 164'.
    They are not cheap though...
    Feb 2012
    Toronto Canada
    They are comparable to a mitubushi slim I'm guessing ?
    Here and there
    Fujitsu system24RLXFW . 164' total combined length. Not cheap but you get what you pay for.
    Quote Originally Posted by #1CDNTECH View Post
    No, the Daikin Sky Air system is a commercial ductless or ducted split
    http://www.daikinac.com/commercial/p...oducts&page=56
    I don't know of any of the typical residentil minisplit split systems that can handle the refrigerant line length you are looking at.
    Dec 2011
    somewhere between here and there
    Good and Cheap!!!
    ROTFLMFAO.........
    you can have it right....
    you can have it fast.....
    you can have it cheap...
    but....
    you ONLY get 2 out of the 3!!!!!!!!!!!
    Please, Please Please......keep the Factory Smoke in the Wires!!!!!
    Is it Rum'Oclock yet???
    Apr 2006
    Barrie Ontario
    What was the price you got on the mits 2 ton cause I know what I pay and I've priced other brands and there's not to much out there I've found cheaper by more than a couple hundred bucks at the most
    For some reason I learn more with my mouth shut
    Mar 2009
    Mount Holly, NC
    don't state pricing on the public forums...
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    A 2 ton 13 SEER Daikin Sky Air heat pump, with wall mount air handler, and their really nice "Navigation controller" wall mount thermostat, costs close to twice as much as a regular Daikin 2 ton 14 SEER ductless split heat pump.
    Something to keep in mind with the commercial type ductless splits is that the indoor unit needs its own power supply, there is only a 2 wire communication line between the indoor and outdoor units.
    Georgia
    Panasonic (used to be Sanyo) has a 2 ton that will go 165'
    Fujitsu has a 2.5 ton that will go 164'
