Results 1 to 13 of 14
    Nov 2009
    CHICAGO
    RTAA 200 AIR COOLED CHILLER
    Hello All:
    This week I will be opening a screw compresor for a Trane RTAA 200 Air Cooled Chiller from 1997. I have a few questions regarding this compressor. I have to replace the slide valve piston and lip seal gaskets. I am wondering if anyone has any tips on performing this job? Or does anyone have a breakdown sheet on this style compressor? Any help would be appreciated!
    Thanks,
    Mike V
    The Hot South
    Quote Originally Posted by honeywell kid View Post
    Hello All:
    Thanks,
    Mike V
    Are you replacing the lip seal gaskets, or are you installing a lip seal reroute kit?
    Nov 2009
    CHICAGO
    Hello 123,
    Im replacing the lip seal gaskets.
    Thanks Mike V
    ottawa canada
    Heres a tip ....If the nut that holds the piston on the shaft wont come undone and it unscrews the nut on the other end .......your royally screwed ...and yes it happens .
    The Hot South
    Hey Graham, Trane came out with a service bullitin for that but it looks like a PITA.
    ottawa canada
    Quote Originally Posted by R123 View Post
    Yes they did and yes its a PITA , you gotta go in the other end of the compressor , pull the stator out and then fix the piston issue and put it all back together , you need some special tools and some funky rigging . It is possible to fix Ive done it .
    Dec 2003
    45th Parallel
    When that happened to me, Pueblo sent me a new comp for free. But that was a few years ago and their probably not as generous anymore.
    I didn't think lip seals were replaceable, when did they start that? Or did you mean the Comp casing o-ring?
    “If your work speaks for itself, don't interrupt.” ~Henry J. Kaiser
    Nov 2009
    CHICAGO
    Hello.
    Sorry i havent been on in a couple day.i will be installing the lip seak kit.and also the slide valve pistion.i do.appreicate the tips.im wondering if anyone has service bulletin on how to install the lip seal kit and slide valve pistion.thanks for taking the time to.read mh issues.
    Thanks mike v
    The Hot South
    As stated by Deivewizard, I also haven't heard of replacing the lip seals. Only the lip seal reroute kit.
    Nov 2009
    CHICAGO
    Hello drive wizard.
    Sorry i ment im installing the lip seal reroute kit.
    The Hot South
    Hello drive wizard.
    That's what I asked you in post # 2 and in post #3 you replied the gaskets.
    Nov 2009
    CHICAGO
    Sorry r123.
    I ment lip seal.reroute kit.
    Not in Iran
    here ya go., dont drop ur nuts!
    Sorry r123.
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
