Results 1 to 13 of 15
    Apr 2012
    Hmm Airconditioner Not Cooling
    Dear Friends,
    Myself Ravi from India
    we have a Voltas 1.5 Ton AC which is 2.5 years old. Last year we refilled gas in it and since last week the AC is not cooling well, it is cooling in spurts.
    So yesterday we called a technician he told that gas needs to be topped up and gave estimate of $/- gas topup + $/- Service Charge
    but today when he came and checked the outdoor unit he told that there is no gas at all in the AC and it will cost $ for full gas recharge, he probably must have released all gas when opening the nut, he mentioned that the gas pipe / pipe from indoor to outdoor unit is full of snow / ice when ac is running means there is no gas at all, ,, then inspite of doing full gas recharge that AC was not cooling well then he checked and told that compressor has got cut off and is not running ,and checked and changed the capacitor. Then he charged additional $/- for the capacitor and the AC started cooling but after half hour again the AC was not working only fan seemed to work and compressor was not working.
    Now again i have phone and called the technician here people are so amateur that any person without any professional qualification can start any trade. Now i am worried what happened to my AC.
    and when itwill work fine.
    Also the technician suggested to install a double booster stabilizer instead of a normal stabilizer. Telling double booster stabilizer will boost even 140 volts to 240 Volts whereas normal stabilizer boosts only 220-230 to 240 VOlts. Can someone suggest what could the probable problem be?
    SW Wisconsin
    It appears so called Tech is NOT a Tech, from here, he appears incompetent.
    Hopefully you can find someone that knows what they're doing...
    hoviwon5220
    Additional infractions may result in loss of posting privileges.
    Your post has been deleted.
    Apr 2012
    again that technician came yesterday evening and checked the indoor unit and cleaned the clogged drain pipe and then little cooling started then in night cooling was ok, but then in day time due to heat or any other reason the compressor is getting cut off after half hour / 45 mins and takes a lot of time you have to switch it off and after 20-30 mins only on it then it will start. I think i need to take some second opinion of some good pro.
    tx
    It does sound like you are in need of a secong opinion. He should be able to see why the compressor is stopping. And as far as the gas, he should be able to locate and fix the leak/s. I hope someone can get you going soon.
    Bad information is worse than no information at all.
    There are three kinds of people in this world. Those who can count and those who can't!
    Si Vis Pacem Parabellum
    Double booster stabilizer? I wonder what that is...
    Minds are like parachutes. They only function when they are open.
    tx
    Quote Originally Posted by albowrx View Post
    From what I could gather from the OP, she must be in an area with very unstable voltage supply, and the "double booster" is supposed to be some sort of constant power supply or transformer supplying a constant voltage source.
    Houston,Tx.
    It keeps the Coagulator from pulling the wires out of the contactor.
    SW Wisconsin
    Cincinnati, Oh
    RSK:
    You should not be leaking any refrigerant.
    I'm not familure with any warranty you may have.
    In the US, any leaking part would be replaced/fixed, and it would usually be covered by some sort of warranty. The labor may or may not, depending on it's warranty.
    It sounds like your tech has no idea what he's doing. Continually adding refrigerant to a 2.5 year old system without repairing the leak is wrong. You will spend much more money in the long run, continuing to add refrigerant than you would repairing the leak.
    I would suggest you find a different company to do business with.
    "Just get it done son."
    Dad adjusted
    id check the bilabial fricative
    Jan 2005
    Littleton, CO
    Good luck. I would get a second opinon as you shouldn't be leaking any freon.
    Become a friend or fan on Facebook
    Beautiful, Philadelphia, the City of Brotherly Love!
    I could stop over for a second opinion, but I don't think you could afford the travel time charge.
