Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 68
  1. #40
    Oct 2010
    At what pressure does the internal bypass on an r22 compressor open? I was thinking around 400psi. My shop has an old Heil builder model 3 ton unit in it that we took out of a customers house about 10 years ago and installed in the shop and it was already 12-15 years old so needless to say its limping along on its last leg and we've definitely got our "money's" worth out of it. I think I'm going to recover the r22 and change the txv to 410a and fill it up with 410a and see how she screams. Maybe I'll get another 25 years out of the POS... Not going to change the oil, just want to keep my head pressure below 400psi when its hot out and hope the compressor can handles the higher pressure. I'm confident the coil will withstand the higher pressure in just not sure about the compressor, guess I'll find out when it warms up this summer.
  2. #41
    Atlanta GA area
    Quote Originally Posted by jtrammel View Post
    What will happen is oil missivity (probably got that term wrong) is not adequate to circulate the oil... the compressor will be starved of oil and self destruct.
    What it means is: The refrigerant and the oil do not mix well... and the refrigerant will not carry the oil back to the compressor. You will have a trashed compressor (from lubrication starvation) in a while.
    I have seen a few 22 pumps make curious noises (similar to a RV valve shifting) when they hit around 400-425. Always assumed (yeah, bad thing to do) this was the internal pressure relief.
    GA-HVAC-Tech
  3. #42
    TIP-O-TX
    Bacon fat, I like it in my refried beans.
    What oil are the Mexicans putting in to the Rheem dry units?
  4. #43
    Chicago, IL
    It won't work. Changing the refrigerant to 410a will increase the capacity to 4-4.5 tons, making both the coils undersized. The compressor will die a quick death.
  5. #44
    Oct 2010
    Quote Originally Posted by craig1 View Post
    I can hardly wait, wonder if it will lock down, blow the peckerhead, ruin the valves, or burn the motor windings.
  6. #45
    Jul 2001
    Anderson,SC
    I'm going to tell your Daddy.
    Stud
  7. #46
    Oct 2010
    Quote Originally Posted by HVAC/Stud View Post
    Stud
    He's in on the experiment.
  8. #47
    Feb 2013
    north georiga
    i'd like to hear the details when your done
  9. #48
    Aug 2010
    Northern Cali
    So this thread has been going for almost a year now. I would like to know how many dry charged r22 units have you installed using r407c ? Has it been successful , have you had any call backs due to using 407c. Do you recommend it? Last summer I was still using r22. But the price around is here is extremely high right now. Thank you for your time.
  10. #49
    Atlanta GA area
    Update: I was at the SureComfort (Rheem/Ruud builder grade name) shop today, free lunch (literally... ).
    I was talking to the store manager... we got to talking about dry units. I mentioned the 407C thing and he said TPTB said NO. I asked if we could go out in the warehouse and look at one... we did. The label has been changed since the one I saw (installed) last summer... it says R-22 only. SOOO...
    I stand corrected (things changed). Now I have no personal knowledge of any dry unit that uses any refrigerant other than R-22.
    Given this fact, as well as the price of R-22... IMO the thing to do is sell them a new 410 system (I am speaking of residential systems).
    GA-HVAC-Tech
  11. #50
    Ky
    I think you'll find that 407 is a blend of 410a and 134a...not sure the proportions, but think it's around 50/50 (of course, they are both blends to begin with). I was also told that POE and mineral do not have a problem together. Have also seen/heard that manufacturers are stating NOT to use 407 instead of 22, or else no warranty.
    LN
  12. #51
    Aug 2010
    Northern Cali
    Well that's funny because I was just at the parts house (united refrigeration) and they told me that there dry charge condensers come with poe oil and are r407c ready. They even recommended it due to the extremely high r22 prices. I think the brand they carry is Thermal Zone, not 100% on that tho. Condensers in my area are getting stolen all the time and some of these customers just don't have the money for a complete change out (rental units). When he told me the price of the r407c it really makes it affordable, However if a couple months down the road when the temps are over 100 degrees I really don't want to get stuck with a bunch of units that cant keep up. What to do? I have 2 units on deck and I need to make a decision.....My out look has always been you get what pay for....and even tho r407c has been around for awhile I have not used it yet
  13. #52
    Atlanta GA area
    What is interesting about that is: Thermalzone is another of the Rheem/Ruud clones...
    Wonder why one clone says no, while another says yes... Curious...
    GA-HVAC-Tech
