Ruud inducer and blower starts but no ignition
i have a ruud gas furnace M#UGTA-10EZAJS. On startup both blower and inducer motor runs, but after so long no ignition happens gas valve doesn't energize and open and hot surface ignitor doesn't energize. I know the air handler blower should not be starting just yet. gas valve or hot surface ignitor is not getting proper voltage. I also notice a small crack in the hose from the negative pressure control to the inducer motor. I don't know if im over looking something or what?
Any answer or tips would be greatly appreciated. thanks.
Get your post count up, show your credentials, and apply for membership.
This is not a DIY site and we don't talk shop with non pro members.
If you are not a service tech, hire one.
Easy fix for a pro. You would be money ahead to call one.
Sound like a temp limit
Replace your air filter, and call for service.
- You may not post replies
- You may not edit your posts
Forum Rules
