Results 14 to 17 of 17
    Aug 2012
    Portland, Or
    Aug 2012
    Quote Originally Posted by Iceman_pdx View Post
    410
    hijacked
    Aug 2012
    Portland, Or
    Thanks Elfshadow I appreciate your help. Will install a check valve in new unit.
    Loud Scroll is Dying Scroll
    Scroll Compressors get noisy when the scrolls turn backwards at shutdown due to reexpansion of the gas through the scroll - not good. They are noisy at startup becasue they are designed to operate well at a relatively narrow range of operating pressure and outside this as with transients at startup the scrolls are unstable and there is metal on metal contact - again not good. Scrolls, while more volumetrically efficient than recips, have much more losses in friction than recips - and once again not good. Recips are used in the tough applications like refrigeration becasue they are very robust and quiet over a very wide range of pressure ratios...go with the recips.
