    Sep 2011
    Fill valve not energizing
    Manitowic q454. The fill valve is not energizing. It just keeps filling with water. The sensor works, light comes on and goes off with level. Any ideas?
    NE Alabama
    So, on this system the fill valve energizing means it opens on power applied, or it's normally closed. If it is filling all the time it has shorted open or has trash in it or aq hole in the diapharm and is leaking by
    Sep 2011
    Fayetteville, NC
    Quote Originally Posted by crymtide View Post
    ditto
    Sep 2011
    Normally open. Closes on power applied. Bench tested solenoid. It works.
    Sep 2011
    OK. I got it. It's the fill valve. When I bench tested, I couldn't blow air through it. Watching start up voltage I can see it supposed to open on voltage applied. When 120 drops out it still flows water. Thanks for brainstorming with me.
