Page 1 of 4 1234 LastLast
Results 1 to 13 of 47
Thread: coil cleaning
    Nov 2007
    Mississippi
    coil cleaning
    Just wondering how everybody else feels about putting chemicals on coils. I know sometimes you got to, but I try not to.
    Sep 2011
    Vancouver, WA
    What does water and dirt make?
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by Williamsma View Post
    A clean coil???
    Sep 2011
    Vancouver, WA
    Talking
    Quote Originally Posted by ammoniadog View Post
    A clean coil???
    I was told years ago water + dirt = mud
    Apr 2012
    Southeast USA
    Used cleaner in the past, but now I use water hose and time. I will use triple d for greasy coils. Only use other chems when its a choice between replacing the coil or using nubrite.
    Dec 2010
    Florida
    To me it’s case by case.
    What coil am I cleaning!
    What kind of water source and pressure do I have to work with..
    Which coil is it! How thick (deep) is the Coil! How clogged is the Coil, What’s on the Coil? Is it in a garage, out back, on a roof, in a closet, suspended in a ceiling??? Will I have to pull the Coil to clean? If I can share one thing with you after cleaning with any chemical….Rinse, Rinse, Rinse and then Rinse again!!
    Mar 2012
    West Chester, PA
    I try to stay away from chemicals unless it is needed. Usually rooftops which reside next to or near a kitchen exhaust get coated with grease and become a real mess. In these situations i use the chemicals but i still usually dilute more than is recomended...
    Dec 2010
    Florida
    Name:  To much Coil cleaner.jpg
    Quote Originally Posted by GroundSquirrel View Post
    that's great lol.
    Dec 2010
    Florida
    Quote Originally Posted by hvac wiz 79 View Post
    that's great lol.
    $4.00 is just the tip of the iceberg
    Dec 2009
    Maryland, Harford County
    never ever have problems with coil cleanings usually salt deterioration causes that
    Dec 2010
    Florida
    Quote Originally Posted by HVAC Mechanic View Post
    Salt is a problem here in Florida thats for sure but, this was not a salt problem. The front of the Coil that was exposed and easily rinsed is just fine. The whole mall had the same units and none were this bad. This particular customer had the Coils cleaned once a year under the Maintenance agreement. This is the result of a lazy persons work or, lack of knowledge on how to use a product.
    NE Alabama
    For my part you follow the mfg directions as to chem strength and rinse long and strong. You are not going to degrade the coil beyond usable condition before it's life span is reached. The problem I most often see is a dirty condenser coil, and many more compressors are lost due to this than coils failing. this goes for hvac as well as refrig or ice machines. In a commercial setting such as a restaurant the contaminants produced by hood exhaust far out weigh the degradation caused by condenser coil cleaning chemicals. Also in an environment like Metro Atlanta the smog factor just adds to the oxidation of aluminum fins and in cleaning AC coils and documenting pressures before and after the benefits of chemical cleaners were immediately evident.
