    Apr 2012
    Log Set for Heat N Glo Dakota 42
    Hello,
    I recently bought a Dakota 42 fireplace that has no log set or burner and I'm trying to work out what type of log to install in it. Am I able to use a third party log such as RH Peterson or Hargrove or do I have to find the original Heat N Glo log set that came with the unit? The interior valve and all other parts are missing so I would need the entire setup but I'm not sure this is necessary.
    Thanks for your help
    S.E. Pa
    Cool
    http://hearthnhome.com/downloads/ser...42-B_42H-B.pdf
    http://hearthnhome.com/downloads/ins...s/4036_909.pdf
    Why do you not have the entire fireplace? Did you buy this used? You should hire a pro familiar with this fireplace to plan its installation in your patio and install it. Note that is an outdoor fireplace.
    You can contact your nearest FireSide Hearth & Home for support as they are owned by the patent company that owns HNG.
    HTH,
    Apr 2012
    Thanks for the reply Hearthman. I bought this from a company that was closing a showroom so this was setup just for display and has no valve / log / etc. Its setup in a masonry enclosure and is meant to be outside but I just need to install a log. I've talked to multiple dealers but get different responses depending on what they want to sell and install. I'm trying to save where I can but need to make sure I'm not causing any safety issues. Do you see a reason why I shouldn't use an RH Peterson log in this application?
