Results 1 to 7 of 7
    york ycas screw comp thermistor posts
    Hi all. New to the forum. I am working on a york ycas 270 ton system. I have to change the thermistor posts (4 0f them) on one of the screws-they have corroded and spade connectors have broken off-does anybody know if i can thread them out without removing the suction plate? York support has not got back to me TWICE. Thanks in advance.
    use a 'Term-Loc'...http://www.term-lok.com/
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Oct 2011
    La.
    Jay is correct, the easy way is the term lock. If however you must replace them, you must remove the end plate. Unless they are rusted through and leaking, use the terminals locks.
    Jun 2010
    U.A. (upper Alabama)
    Which ever route you go, be sure to coat them with liquid rubber so they don't rust again.
    Dec 2008
    Dixiana, AL
    They'll unscrew.
    Jul 2011
    Columbus, Ohio
    They will unscrew, just be real careful the wire does not come off as you pull it up through the hole. Pre twist the wire befour putting the new one back in. Done it this way several times, got burned only once, because the wires were tangled inside and would not twist enough to get it unthreaded.
    thank you all-i can't use the term locks, i have to replace them. Tried unthreading one of them, could not get the internal wiring up through the hole- it eventually came off inside- will have to remove the end plate! Is there any risk of damaging wiring or thermistors after removing the plate?
