Results 1 to 9 of 9
Thread: Cond fan motor in airhandler?
04-05-2012, 06:29 PM #1
- May 2005
- Florida
- 572
So theres (now) this guy way out in the middle of bfe with a 1/3 hp 1075 condenser fan motor in his airhandler thanks to my non stocked truck. It's a 2000 trane that had the original vented 1/3 1075 in it that burned up.
It draws normal amps. Seems like people would do this back before ecm motors. It'll be fine right? Not that I really care.
04-05-2012, 06:40 PM #2
Professional Member*
- Jul 2010
- nebraska
- 1,176
His Nebraska cousin( also in BFE) has the same thing and it has been going strong for 5 years.
04-05-2012, 06:47 PM #3
It gets pretty hot in Egypt. I wouldn't use a TENV motor.
04-05-2012, 06:52 PM #4
- Dec 2011
- bedford ind
- 1,080
That's a relief! Thought I was the only one. I put one in a garage that had a sandblaster.The sand kept getting in the air-over motors windings.
04-05-2012, 10:14 PM #5
- Apr 2012
- 10
Ive put several of them in, especially in dusty or high humidity environments
04-06-2012, 07:05 AM #6
- Jun 2001
- Moore, Oklahoma
- 2,595
As long as the voltages are the same and they don't need multispeed i don't see why not..
04-06-2012, 07:41 AM #7
Ive done it many times in a pinch and havnt had any issues. As long as your amp draw was good the motor should actually stay cooler than if used outside.
04-06-2012, 07:47 AM #8
I've considered doing it mostly for the cost savings. But from what I've seen the amps on the condenser motors are usually too low to use for a blower motor regardless of the HP.
04-06-2012, 09:04 PM #9
- Jun 2001
- Moore, Oklahoma
- 2,595
Are condenser motors not more efficient since they are mostly single speed? This may account for some of the lower amperage?
