Results 1 to 11 of 11
    Apr 2012
    NC
    Choosing between two Lennox systems
    I am in a process looking for a replacement of upstairs HVAC system. Total house is 3800 sqft, currently have two identical 15 y.o 2.5 tons noname systems.
    Have two similary priced quotes on Lennox HVAC systems.
    First is 3 ton XC13 (14 SEER) / CX34 / ML180E.
    Second is 2.5 ton 13ACX (13 SEER) / CX34 / SL280V
    First system is bigger and has better AC unit ("Elite Series") and basic furnace. Second is smaller and has basic AC and much better variable speed furnace ("Signature Series"). My current furnance is OK, i.e. it heating is not a problem. Cooling on the other hand was an issue updtair for the last several years.
    Should I go with better AC or a better furnace? I am told that variable speed furnace will improve overall SEER rating of the system. And in the end both system will have similar SEER ratings.
    Thanks!
    Virginia
    Ave you looked at the xc14 ,depending on the age of the furnace might do it all at 1 time
    Apr 2012
    NC
    Thanks for reply!
    XC14 alone is quoted slightly less ($500) then cheap AC + furnace. Furnace is 15 y.o., it looks like I am getting a new furnace for $500.
    Apr 2012
    NC
    Got AHRI ratings for both systems:
    3.0 ton XC13 (14 SEER) / CX34 / ML180E - 14.5 SEER
    2.5 ton 13ACX (13 SEER) / CX34 / SL280V - 15.0 SEER
    Should I go with 2nd system?
    Mar 2010
    North Ridgeville, Ohio
    I would pick the second system with variable speed and merit series A/C. I am a Lennox dealer and that unit has proven to be very good. Variable speed does allow for higher seer as well as improved IAQ.
    Sent from my Desire HD using Tapatalk
    Do, or do not. There is no try.
    Mar 2010
    Just make sure you have a quality contractor that is going to do the install properly.
    Jun 2007
    Greenwood Indiana (Indianapolis)
    Thumbs up
    Quote Originally Posted by crewbar View Post
    Thanks!
    why not get a quote on the xc13 and the sl280v. Also you may try the xc16, 2 speed a/c 3 ton. Will run at 2 ton on milder days like at night time when the outside cools down a little and when its hotter out, it kicks into 3 ton. This will be a system that will dehumidify the air and home way better than either of those 2 systems you mentioned. NOTE, must go with the variable speed furnace to operate a 2 speed a/c properly.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Apr 2012
    NC
    Quote Originally Posted by sideburns05 View Post
    I like the installer of second system more. I have a duct problem and every installer suggested some ways to resolve it. This installer have most extensive plan for rebuilding ducting.
    The only concern left is refrigerant lines. He is going to install one new (because it's uses different coolant?) and reuse other (or two others). Is it Ok or should I try to get all lines replaced?
    Thanks!
    Apr 2012
    NC
    Quote Originally Posted by Kevin Weaver View Post
    I have a quote for XC13/SL280 and it significantly more expensive (additional 15%-20% of the total). I am not sure I will ever get a return on this investment. Our electricity rates are low (8c/kWh).
    Apr 2012
    NC
    Also, I've just checked a parts site. XC13 and 13ACX share all major parts. Same compressor, motor/fan, contactor, capacitor. Exterior is different.
    What are the advantages of XC13 over 13ACX?
    Mar 2010
    Different case design and quieter not too much of a difference. I would have him change both lines if you are going from r22 to 410A refrigerant. If that is not plausible then the lines will need to flushed to insure a long efficient life of the compressor
