Results 1 to 13 of 15
Thread: CLothes Dryer CFM's
06-01-2006, 04:27 PM #1
- Apr 2005
- 8
How many CFM does a typical residential clothes dryer pull from a room?
06-01-2006, 04:45 PM #2
New Guest
- May 2006
- 80
First select the best description of the unit,
1.Fat
2.Skinny
3.Ugly
4.Pretty
5.Tall
6.Short
7.Deep
8.Shallow
Nobody can tell the cfm without more infomation,
look on the blower motor, fan or manual.
06-01-2006, 05:15 PM #3
- Mar 2005
- Houston, Texas
- 11,646
BTU's ,please.
06-01-2006, 05:54 PM #4
Dryer airflow
If it is like my gas dryer, it appears to be about a hundred CFM. It exits air through a 4-inch vent, in the absence of any measuring equipment you might estimate based on air speed of 600-1000 feet/min. Do you need anything more precise?
It might be interesting to know why you ask.
-- Pstu
06-01-2006, 06:14 PM #5
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Most are 120 to 150 cfms ,IF the 4" vent is not too long,restricted ,or has too many elbows.
They are designed for a maximum od 25' of duct,with each 90° elbow counted as 5' of duct.Now I have heard some newe ones are designed for longer vent duct ,but i haven't seen that in print yet.
06-01-2006, 07:16 PM #6
- Feb 2003
- Huntsville,AL
- 4,125
for duct runs over 5ft, use an inverted reducer to 6inch smoke grade pipe & ells, then reduce back down to get standard dryer thru- the- wall fitting = lo back pressure!
-- like mine = 3 turns ~30ft = NO lint collection at last ell before exiting, flap stands straight out when dryer is run -- but only for 4y, now. ps, I applied fiberglass wrap to keep gar cooler in summer -- just dump air in winter.
make it big, bury it deep!
are you trying to supply makeup air for
combustion?
ventilation?
or, just get rid of hot air?
[sometimes, lots of that around]
[Edited by cem-bsee on 06-01-2006 at 07:21 PM]harvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
06-02-2006, 04:54 PM #7
- Apr 2005
- 8
Sorry, I should have made it clear that I didn't need specifics. I was guessing about 150 cfm.
I was just wondering because it's in our basement in a room that doesn't see much circulation.
06-03-2006, 01:33 AM #8
Banned
- May 2006
- 489
You may want to consider a ventless clothes dryer. Instead of venting the moisture, a compressor-based heat pump (operating as a dehumidifier) extracts it and recycles a lot of the heat. As a result, it costs less to operate and puts less load on your A/C.
06-03-2006, 09:12 AM #9
Banned
- Aug 2002
- 18,836
Do you have a link for that product??Originally posted by star882
06-03-2006, 09:44 AM #10Seen one like that in popular mechanics about 10 years ago. Need to blow that lint outside though.Originally posted by dash
Typical clothes dryer about 160 to 200 CFM
06-03-2006, 09:47 AM #11
Banned
- May 2006
- 489
http://us.lge.com/products/model/det...WM3677HW.jhtmlOriginally posted by dash
That's the one I have. Beware that it uses a rotary compressor (based on the sound) and is pretty noisy on the dry cycle. (However, it's not as noisy as the spin cycle.)
06-03-2006, 06:52 PM #12
LONG CYCLE
On that type of dryer, it takes a VERY long time to dry. We got a memo to give heads up to customer, that it may take about 2-3 hours to do a load!
06-03-2006, 09:15 PM #13
Banned
- May 2006
- 489
Re: LONG CYCLE
That's due to the lower temperatures and the need to clean the coils. The condenser doesn't get as hot as the heater in a regular clothes dryer, and every once in a while (based on high side pressure I believe), the compressor stops and the automatic coil cleaner turns on (the lint is washed off and leaves with the drain water). I question the reliability of the compressor a little (as it operates at temperatures and pressures higher than the ones in A/Cs), but it's specially designed for this application and I have not heard a single failure report. Only time will tell how long the compressor will last.Originally posted by mayguy
Nonetheless, for those who do laundry frequently, the energy savings can easily offset the higher price of the unit. The lower temperatures are also gentler on clothing. And best of all, no need to move clothing from the washer to the dryer!
