Results 1 to 12 of 12
    May 2009
    Waterloo Ontario
    Dual Fuel at my father in laws cottage
    a couple pictures.
    this is mid state, i didnt finish as he came back with a couple cases of tall coors. next weekend perhaps
    Jan 2011
    I like to lay strut ontop of the other strut running the length of the furnace, coil and filterbox. Keeps things from sagging, which will eventually happen.
    Atlanta, GA
    That's a big coil.
    Jun 2011
    Seattle WA
    There's no supply air or venting. Thats against code you know
    -Alfred E Newman
    Chicago, IL
    Quote Originally Posted by jimmyed View Post
    agreed
    it also allows you to put the hangers beyond the ends of the furnace so you can get the blower assembly out when the motor fails.
    Jacksonville, FL.
    Also, from a service point-of-view, that condenser is pretty close to that wall!
    WHY?
    Feb 2012
    You know I dont think the unistrut is ever going to sag. It looks like it is the 1 1/2 think strut. But I could never understand as to why everybody always has the strut open on the bottom. If it is open on top it makes it a lot easyer to raise and lower as needed. Also the flanges you used to the bottom of the joist's. I like to use sideways sammys halfway up the side of the joist. Wheres the saftey pan?
    May 2009
    Waterloo Ontario
    Quote Originally Posted by Random Guy View Post
    That's a big coil.
    The horizontal coils are huge, plus it is a 3 ton coil.
    Quote Originally Posted by Special Ed View Post
    It's actually almost 9" lots of room to remove the grill.
    Quote Originally Posted by honeybadger View Post
    Safety pan? please explain?
    Mar 2009
    Mount Holly, NC
    Quote Originally Posted by Purcell1 View Post
    ... read the installation guide for the condenser... most specify a MINIMUM of 12" and 18 is recommended.
    I am yourmrfixit
    Mar 2009
    Mount Holly, NC
    most don't use hanging strut unless it's in an attic... he likely thought it was in an attic, so would require a pan...
    I am yourmrfixit
    Afton, VA / Khorat, Thailand
    So far, so good. A few Coors might just help it along......
    Midnight Sun Astrophotography
    Apr 2012
    Pad looks awful small, it might be a leaner soon
