Results 1 to 13 of 17
    Jun 2001
    4 wire battery powered thermostats
    New to the industry and I'm surprised how often battery powered 4 wire stats are being used on systems that have 5 wires available. I would have thought 5 wire stats powered through the common terminal would have been standard on a 5 wire system. Most of these are not homeowner installed, some even have company logos printed on them.
    Feb 2012
    Opelousas La.
    Also on some stats that can use batteries or hard wired, when the batteries are installed the time delay function is not used.
    Mar 2012
    copperas cove
    Quote Originally Posted by La Air Man View Post
    I am pretty sure Time delay will work with a common or with batterys.
    Jun 2001
    All the thermostats we install are powered by common wire. Sometimes we have to use an "add a wire" kit to get them to work when there is only 4 thermostat wires. Most times 5 wire cable is pulled but the contractor never hooked up the common and decided to use a battery powered stat instead.
    Southeastern Pa
    The batteries are there to retain time and schedule on stats during power losses.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2001
    The ones we install require a common wire to operate and a lithium battery for backup. Most of the old ones use the batteries for operation, no common wire connected.
    I see this all to often as well, ALL by pros.
    I always connect them and let the HO know why.
    I just don't get it either.
    Cincinnati, Oh
    If your refering to compressor lock, then it's only partially correct.
    If a homeowner cycles the equitment manually, then it would wait the 5 minutes.
    If it attemps to cycle due to a lack of power, then it would not wait the 5 minutes.
    This is due to the thermostat not noticing the lack of power.
    "Just get it done son."
    Dad adjusted
    Nov 2007
    Sherman, TX
    We get frequent service calls on Honeywell and White-Rodgers digital stats, where the system won't run at all, and the only problem is dead batteries.
    If a 5th wire is there, we use it and hook it to common. If not, then it's batteries. They usually last a good long time....like well over a year.
    A good item to check/replace when doing PMs....
    Technical incompetence is NOT a sales tool....
    Jun 2010
    CA
    umm yea, in case of a power outage, the t-stat dosent go off, that way it keeps its stored memory.
    Southeastern Pa
    ...and yes, hook up the common whenever possible.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    north suburbs of Chicago
    Quote Originally Posted by John Markl View Post
    Yep, and you look good for thinking about it as well. I have very few jobs that have extra wires to use anyway.
    Jun 2001
    Is 5 wire cable that much more than 4 wire? IMHO when there is only 4 wires it's better to use the fan wire as a common and disable the fan auto/on switch. Hook Y to G at the furnace board and call it good.
