Thread: ductwork
05-31-2006, 12:24 PM #1
- Apr 2004
- 82
my supply ductwork is all metal except for the last 6 ft of each run which is flex. a/c guy said this makes for a tighter system and the flex baffles air noise and hooks to the supply boots easier. the air noise is more noticeable than other systems that have all flex. is more air noise normal because of so much hard pipe?
05-31-2006, 01:27 PM #2
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Yes ,that or the ducts are on the small side ,causing higher velocity air thru them.
06-02-2006, 04:35 PM #3
- May 2006
- Arlington, TX
- 105
Agreed. Static losses on sheet metal ductwork are much less than their flex counterparts, however, which means less fan power used and better efficiency.
06-03-2006, 09:05 AM #4
Banned
- Aug 2002
- 18,836
Sized corectly ,flex and metal can perform the same,yes, the flex sizes will be larger then the metal to get the same performance.Originally posted by leander311
06-04-2006, 12:56 PM #5
- May 2006
- Arlington, TX
- 105
Yes, larger flex duct can have the same friction losses as smaller metal duct. But then you have lower velocities and greater surface area per length, which means more conductive losses through duct walls, reducing effective efficiency.
06-04-2006, 08:10 PM #6
- Feb 2005
- Toms River, NJ
- 415
I agree with dash. If you know how to use a ductulator properly you can move mountains. All metal duct systems IN GENERAL tend to resonate making more noise. You can make metal system airtight by simply using mastic on all the joints. I'm assuming we are talking about a basement..flex in a basement looks like $hit, but what are you gonna do
Dave in NJ
