Results 1 to 13 of 14
04-03-2012, 08:07 PM #1
- Feb 2001
- 432
wirelessly communicating thermostats
Current thermostat for a Ruud 2.5 ton heat pump is a broken Braeburn and will be replaced on Friday. It's downstairs, and the single return is upstairs. Does there exist a pair of thermostats that communicate wirelessly, with the downstairs stat wired in the usual manner and the upstairs stat either battery powered or line voltage. The idea being that the HO could choose which stat governs at any given time. Has anybody seen a reliable pair of this type?
04-03-2012, 08:44 PM #2Make your expertise uniquely valuable.
Make your influence uniquely far-reaching.
04-03-2012, 08:53 PM #3
- Feb 2001
- 432
Hmmm. Not exactly what I had in mind. There is no need to display outdoor temperature and humidity, and this is not a zoned system.
04-03-2012, 09:02 PM #4
You need to look a little more.
http://www.forwardthinking.honeywell...ks/50-1311.pdfMake your expertise uniquely valuable.
04-03-2012, 09:04 PM #5Make your expertise uniquely valuable.
04-03-2012, 09:15 PM #6
- Feb 2001
- 432
Honeywell is certainly a good brand, but still looks like too many bells and whistles. What do you see that looks like a good match?
04-03-2012, 09:20 PM #7
A Prestige stat and a portable comfort control is what you need.
Wire the Prestige downstairs and take the wireless comfort control upstairs,You tell it which one you want to control the system.Make your expertise uniquely valuable.
04-03-2012, 09:47 PM #8
- Feb 2001
- 432
Alright. Are there any other competing brands I should consider?
04-03-2012, 11:58 PM #9
Professional Member*
- Feb 2009
- Portland OR
- 1,509
Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
Like us on FACEBOOK if you like our advice here!
04-04-2012, 11:34 AM #10
- Feb 2001
- 432
Current stat does NOT read outdoor temp, and the system is not designed for lowest operating cost. I still think the Honeywell pair has too many bells and whistles. I'm just trying to find the lowest cost solution to upstairs comfort issues. Sometimes on winter nights (when the heat strips kick in) the upstairs temp goes above 80 when the downstairs stat is set at 68.
04-04-2012, 08:43 PM #11
- Dec 2010
- Palm Beach,Fl.
- 870
http://www.forwardthinking.honeywell...ocusPRO_LR.pdf
Here is a slightly simpler Honeywell set up. The stat itself is very basic and can still be linked to the portable remote. Outdoor temp is an optional accessory. I have not seen a comparable product from any other brand. Even if there was, Honeywell does it better
04-04-2012, 08:51 PM #12
04-04-2012, 08:57 PM #13
- Feb 2001
- 432
