Results 1 to 13 of 19
    Dec 2011
    louisiana
    testing for non-condensables
    Can someone explain this "comparison between the liquid refrigerant pressure and corresponding saturation temperature at ambient conditions " can show if non-condensables or foreign gases are present???
    I mean excessive high side pressure does not always mean moisture in system, could be over charge, no fan (ok, some things are obvious), but exactly how can I use these tests to pin down moisture?
    Greg
    Chicago area
    The test
    add a pressure tap to the inside of the condenser, if there is not one already.
    Close the refrigeration service valves. Turn on ONLY THE FAN.
    let it run for a few minutes. Test the pressure and compare to the corresponding temperature on the gauge. That temperature should match the outdoor ambient.
    I am not aware of this test being accurate when the system is running.
    This test can also be useful in finding what refrigerant is in the system on refrigeration units.
    Dec 2011
    louisiana
    Could you explain the science behind this? I guess I never thought the refrigerant was in a liquid state in the condensor coil when the unit was off. So if moisture is present, corresponding temp would be off(higher?), fan is to ...?
    Thanks for your help
    Greg
    Lancaster PA
    The fan is to coll the refrigerant to ambient temp. Without the fan running, solar heat could raise the temp and pressure of the refrigerant above the ambient temp.
    Apr 2005
    see below>>>
    Jason J Saylor
    Lockheed Martin
    HVAC Tech
    Meymanah,Afghanistan
    "You will encounter many distractions and many temptations to put your goals aside: The security of a job, a wife who wants kids, Whatever. But if you hang in there, always following your vision, I have no doubt you will succeed.”
    Larry Flynt quote
    Apr 2005
    Quote Originally Posted by thecarpenter View Post
    Greg
    The Science behind it is Every freon has a Temp/Pressure Chart and The pressure is Relative to the ambiant air. For example I can put a pressure gauge on a Can of R22 freon and compare that to a PT chart and tell you the ambiant air temp. Now IF i know the AMbiant temp, and Know the pressure of the Gas and have a chart I can
    Jason J Saylor
    Lockheed Martin
    HVAC Tech
    Larry Flynt quote
    Nov 2011
    Charleston, Wv.
    Dalton's Law....the law of partial pressures, states: that the total pressure of a mixture of gasses is equal to the sum of their individual pressures.
    Quote Originally Posted by 71CHOPS View Post
    Pure refrigerant will reflect the pressures on the PT chart. Those pressures are saturation pressures. Yes, it means that liquid can be present, but vapor can also be present at those temperatures. It's called saturation.
    Add non-condensible gasses to the container (system) and you will see higher pressures.
    Jun 2011
    Nice test. Thanks!
    And the only place a P/T chart is accurate is when there is a mixture of liquid and gas i.e. the cond. or evap. coils.
    Quote Originally Posted by woody19 View Post
    Yes.
    Where it gets exciting is when dealing with blends and the temperature glide.
    Jun 2009
    Pompano Bch, S Fla
    Came across this thread and I don't know what exactly a pressure tap is. Is it a line piercing valve? If so, don't those have a reputation for leaking after a while? Any info would be greatly appreciated. Thanks in advance.
    Jun 2012
    Great lakes
    Quote Originally Posted by Pete954 View Post
    Self piercing valves are for DIY home owners, under bid jobs, or lazy techs. They do not exist in refrigeration systems.
