Page 3 of 9 FirstFirst 123456789 LastLast
Results 27 to 39 of 111
  1. #27
    Atlanta area
    Looks like SpaceX's webcast will begin at 3:00, not 3:15.
    http://www.spacex.com/webcast/
    (It probably won't make any difference in the overall scheme of things, but you never know.)
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
  2. #28
    Atlanta area
    Sweet!
    What a fireball there was coming off the back of the rocket!
    And it was square!
    What a smooth launch.
    SpaceX had their own talking-head TV show this time. They
    had three of their own people in Hawthorne giving the play
    by play on the SpaceX webcast.
    The webcast showed streaming video of Falcon 9 stage
    separation and solar array deployment after NASA video
    lost sight of the rocket and switched to mission control.
    SpaceX's Falcon 9 video telemetry dropped out at about
    T+13:45.
    When the solar array was deployed, a large crowd of
    employees roared with cheering and applause.
    Dragon is in orbit and under way.
    Vacuum Technology:
  3. #29
    Atlanta area
    Here's the SpaceX Show:
    http://www.youtube.com/watch?v=DB8Gb...feature=relmfu
    Go to 1:06:00.
    Oops, my bad. This is the aborted launch.
    I missed this show on the 19th. When I
    went to the Spacex.com streaming video link,
    all I found was the Livestream video from the
    launchpad, so I watched most of it on Ustream.
    Vacuum Technology:
  4. #30
    Atlanta area
    Spacex video of the launch and flight, including stage separation and solar array deployment: http://www.youtube.com/watch?v=julrL3o_yow
    Elon Musk during liftoff:
    http://vimeo.com/42608732
    Spacex employees cheer at liftoff:
    http://vimeo.com/42608730
    Solar array deploys:
    http://vimeo.com/42614475
    Webcast hosts celebrate with employees as solar array locks in position and Dragon begins orbital operations:
    http://vimeo.com/42614476
    Vacuum Technology:
  5. #31
    Atlanta area
    HERE it is!
    This is the SpaceX webcast of the
    Falcon 9 launch on 22 May 2012.
    http://www.youtube.com/watch?v=O-gSkGQnFR8
    Vacuum Technology:
  6. #32
    Atlanta area
    Track Dragon and the ISS across the globe:
    Dragon: http://www.n2yo.com/?s=38348
    ISS: http://www.n2yo.com/?s=25544
    Both:http://www.n2yo.com/?s=25544|38348
    See an interactive 360 view of Dragon interior:
    http://www.spacex.com/panorama/index.html
    Vacuum Technology:
  7. #33
    Atlanta area
    How Elon Musk got into the rocket business,
    some insight into how Elon thinks,
    why rockets are designed to be expensive and complex,
    and how SpaceX is changing some critical priorities in
    the rocket business:
    http://www.airspacemag.com/space-exp...Employees.html
    (This is not a boring article.)
    Vacuum Technology:
  8. #34
    Atlanta area
    When will it be in your neighborhood?
    http://www.spaceweather.com/flybys/?...jbc7usnkh23q73
    Vacuum Technology:
  9. #35
    Atlanta area
    Vacuum Technology:
  10. #36
    Atlanta area
    Dragon Videos
    The Dragon took several hours to approach the ISS. Most of this time was spent holding position while data was checked and safety was confirmed.
    The approach was delayed for a while because one of Dragon's two LIDARs (aka LADAR in military circles) was bouncing laser off a spot on the ISS which was a different distance than the spot the other laser was aimed at. The LIDAR ranging info was compared to info from the IR (infrared) range detectors (which were referred to as thermal imagers because they had the added (superfluous) benefit of providing a heat picture of the ISS). The ranging issue was resolved by backing away for a while and tightening the laser beam.
    Normally only one LIDAR is required, but SpaceX took two so they could verify the precision of the equipment and software.
    These are early approach videos. There's not a lot to see (except a couple of Russian spacecraft suckling at the ISS, a lot of clouds, and the occasional Dragon retro rocket), but there is plenty of interesting and informative commentary:
    http://www.youtube.com/watch?v=m6_h2...feature=relmfu
    http://www.youtube.com/watch?v=MX9Pb...feature=relmfu
    These are edited and compressed videos of the berthing:
    http://www.youtube.com/watch?v=DbKP6V_O5qM
    http://www.youtube.com/watch?v=2WAY7boAE68
    The guy who did these videos has a YouTube channel and a very nifty website:
    http://www.youtube.com/user/SpaceVidsNet
    http://spacevids.info/
    Vacuum Technology:
  11. #37
    Atlanta area
    Vacuum Technology:
  12. #38
    Atlanta area
    The Kennedy Space Center video feed in post #16 may have been a dud SpaceX-wise, but it looks like they're gearing up for Orbital's upcoming launch of the NuSTAR X-ray telescope on (or after) 13 June. The telescope will be carried by a Pegasus missile, which will be dropped from Orbital's L-1011 jet.
    http://countdown.ksc.nasa.gov/elv/
    http://www.nasa.gov/missions/highlights/schedule.html
    http://www.space.com/14937-nustar-bl...fographic.html
    http://www.ustream.tv/recorded/22959343
    http://www.space.com/15903-nasa-blac...r-mission.html
    http://search.nasa.gov/search/search...ustar#~gsa~1~0
    http://en.wikipedia.org/wiki/Orbital...es_Corporation
    Vacuum Technology:
  13. #39
    Atlanta area
    Vacuum Technology:
