Results 27 to 39 of 79
05-21-2012, 10:35 PM #27
- May 2007
- Atlanta area
- 1,657
Looks like SpaceX's webcast will begin at 3:00, not 3:15.
http://www.spacex.com/webcast/
(It probably won't make any difference in the overall scheme of things, but you never know.)Vacuum Technology:
CRUD = Contamination Resulting in Undesirable Deposits.
CRAPP = Contamination Resulting in Additional Partial Pressure.
Change your vacuum pump oil now.
Test. Testing, 1,2,3.
05-22-2012, 04:32 AM #28
- May 2007
- Atlanta area
- 1,657
Sweet!
What a fireball there was coming off the back of the rocket!
And it was square!
What a smooth launch.
SpaceX had their own talking-head TV show this time. They
had three of their own people in Hawthorne giving the play
by play on the SpaceX webcast.
The webcast showed streaming video of Falcon 9 stage
separation and solar array deployment after NASA video
lost sight of the rocket and switched to mission control.
SpaceX's Falcon 9 video telemetry dropped out at about
T+13:45.
When the solar array was deployed, a large crowd of
employees roared with cheering and applause.
Dragon is in orbit and under way.Vacuum Technology:
05-22-2012, 05:07 AM #29
- May 2007
- Atlanta area
- 1,657
Here's the SpaceX Show:
Go to 1:06:00.
Oops, my bad. This is the aborted launch.
I missed this show on the 19th. When I
went to the Spacex.com streaming video link,
all I found was the Livestream video from the
launchpad, so I watched most of it on Ustream.Last edited by Space Racer; 05-22-2012 at 05:33 AM.
Vacuum Technology:
05-22-2012, 04:01 PM #30
- May 2007
- Atlanta area
- 1,657
Spacex video of the launch and flight, including stage separation and solar array deployment:
Elon Musk during liftoff:
http://vimeo.com/42608732
Spacex employees cheer at liftoff:
http://vimeo.com/42608730
Solar array deploys:
http://vimeo.com/42614475
Webcast hosts celebrate with employees as solar array locks in position and Dragon begins orbital operations:
http://vimeo.com/42614476Last edited by Space Racer; 05-22-2012 at 04:31 PM.
Vacuum Technology:
05-22-2012, 08:07 PM #31
- May 2007
- Atlanta area
- 1,657
HERE it is!
This is the SpaceX webcast of the
Falcon 9 launch on 22 May 2012.
Vacuum Technology:
05-23-2012, 04:58 AM #32
- May 2007
- Atlanta area
- 1,657
Track Dragon and the ISS across the globe:
Dragon: http://www.n2yo.com/?s=38348
ISS: http://www.n2yo.com/?s=25544
Both:http://www.n2yo.com/?s=25544|38348
See an interactive 360 view of Dragon interior:
http://www.spacex.com/panorama/index.htmlVacuum Technology:
05-23-2012, 02:14 PM #33
- May 2007
- Atlanta area
- 1,657
How Elon Musk got into the rocket business,
some insight into how Elon thinks,
why rockets are designed to be expensive and complex,
and how SpaceX is changing some critical priorities in
the rocket business:
http://www.airspacemag.com/space-exp...Employees.html
(This is not a boring article.)Last edited by beenthere; 05-23-2012 at 06:17 PM. Reason: Pe posters request
Vacuum Technology:
05-23-2012, 05:47 PM #34
- May 2007
- Atlanta area
- 1,657
When will it be in your neighborhood?
http://www.spaceweather.com/flybys/?...jbc7usnkh23q73Vacuum Technology:
05-24-2012, 09:17 PM #35
- May 2007
- Atlanta area
- 1,657
TRUCKS...IN...SPAACE
http://www.space.com/15703-space-sta...ps-photos.htmlVacuum Technology:
05-25-2012, 06:50 PM #36
- May 2007
- Atlanta area
- 1,657
Dragon Videos
The Dragon took several hours to approach the ISS. Most of this time was spent holding position while data was checked and safety was confirmed.
The approach was delayed for a while because one of Dragon's two LIDARs (aka LADAR in military circles) was bouncing laser off a spot on the ISS which was a different distance than the spot the other laser was aimed at. The LIDAR ranging info was compared to info from the IR (infrared) range detectors (which were referred to as thermal imagers because they had the added (superfluous) benefit of providing a heat picture of the ISS). The ranging issue was resolved by backing away for a while and tightening the laser beam.
Normally only one LIDAR is required, but SpaceX took two so they could verify the precision of the equipment and software.
These are early approach videos. There's not a lot to see (except a couple of Russian spacecraft suckling at the ISS, a lot of clouds, and the occasional Dragon retro rocket), but there is plenty of interesting and informative commentary:
These are edited and compressed videos of the berthing:
The guy who did these videos has a YouTube channel and a very nifty website:
http://www.youtube.com/user/SpaceVidsNet
http://spacevids.info/Last edited by Space Racer; 05-25-2012 at 07:11 PM.
Vacuum Technology:
05-27-2012, 06:29 PM #37
- May 2007
- Atlanta area
- 1,657
Another Dragon video:
Andre Kuipers's photo stream on flikr:
http://www.flickr.com/photos/astro_a...n/photostream/Vacuum Technology:
05-31-2012, 03:21 AM #38
- May 2007
- Atlanta area
- 1,657
The Kennedy Space Center video feed in post #16 may have been a dud SpaceX-wise, but it looks like they're gearing up for Orbital's upcoming launch of the NuSTAR X-ray telescope on (or after) 13 June. The telescope will be carried by a Pegasus missile, which will be dropped from Orbital's L-1011 jet.
http://countdown.ksc.nasa.gov/elv/
http://www.nasa.gov/missions/highlights/schedule.html
http://www.space.com/14937-nustar-bl...fographic.html
http://www.ustream.tv/recorded/22959343
http://www.space.com/15903-nasa-blac...r-mission.html
http://search.nasa.gov/search/search...ustar#~gsa~1~0
http://en.wikipedia.org/wiki/Orbital...es_CorporationVacuum Technology:
06-01-2012, 05:03 AM #39
- May 2007
- Atlanta area
- 1,657
Dragon in the water:
http://vimeo.com/43203563
Dragon on the barge:
http://spacexlaunch.zenfolio.com/p20...41bb8#he241bb8Vacuum Technology:
