Results 1 to 13 of 14
    Tucson, Arizona
    ground mount package
    We re-ducted this unit a few years back, I need to get after pics. They put a start collar into the window opening and taped a filter to it. We poured a slab and cut in a return with filter grille and used rigid duct with 2" liner.
    Apr 2011
    Independence, MO.
    Kansas city? oh wait, cant be you still have a coil in the unit.
    Tucson, Arizona
    What??
    What? Kansas city? Nope Tucson Arizona. Both coils still there and working well, it's not in the city but a little outside, kind of a nicer, private area.
    Jan 2012
    Tallahassee,Fl
    Wow?
    Does the supply go up to the roof and tap into where the old swamp cooler used to sit?
    RSES Certificate Member
    RSES-SWRA President
    Tucson, Arizona
    Mark, Basically, the cooler sat on the angle iron stand in the corner of the picture, flex duct connected to swamp cooler duct that fed into the soffit. Up near the eaves, very close to the roof.
    Afton, VA / Khorat, Thailand
    Is flex outside even legal there, much less smart...?
    Midnight Sun Astrophotography
    Jan 2006
    McQueeney, Texas
    I guess they are considering that to be a portable unit.
    Tucson, Arizona
    Flex duct won't last a year outside here. The mylar jacket is quickly disinegrated. Legally the flex can't be installed outside, I've seen it fill with water on new construction before the roofing is done. I think the water permiates thru the jacket but not the core typically. I will drive by this house in the next couple of days to share the after pics. I've seen too many jobs flexed outside, it's sad. Can flex be installed outdoors in other parts of the country? I was in northern California last month and seen Flexable duct connections on a package unit and plastic fittings on the carflex. We must cover the flex connectors with metal to protect it from the sun here, and use metal carflex fitting or they turn black and brittle after just one summer, PVC must be painted aswell.
    Jun 2009
    Alberta, Canada
    whaT kind of abomination is that??
    Have tools and gauges, will travel.
    RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
    Mar 2011
    NC
    Who cares about the installation, I'm sure they got a good deal!
    You Get What You Pay For
    Feb 2012
    Chile
    Now I know what a $1300 installed unit looks like
    Mar 2011
    NC
    Quote Originally Posted by Moonrunner View Post
    That's the cost of the unit, the duct job was about $13.00
