Results 1 to 11 of 11
Thread: Cooltube
03-29-2012, 03:48 PM #1
Cooltube
Okay fellas, anyone played with these yet?
http://www.cooltube.com/The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
03-29-2012, 04:35 PM #2
Not bad... would have been nice to have something like this when I was still sniffing refrigerant.
03-29-2012, 05:01 PM #3I've used one before. It was an a oooooold hussmann salad bar which wasn't designed to maintain temperature requirements by today's standards.
Installed cool tube, aimed it right at the bottoms of the pans and it's been running great since, no problem maintaining product temperatures below 41*
03-29-2012, 05:34 PM #4These have been talked about here before...as far back as 2004:
http://hvac-talk.com/vbb/showthread.php?t=59548
...and again in 2011:
http://hvac-talk.com/vbb/showthread.php?t=888172
So they've been around for a while.
I can't see how they can cram as much capacity into a given length as compared to a finned coil of the same length.
How would do you control one with a constant cut-in tstat?
I see condensate drain issues, too.
03-29-2012, 06:40 PM #5I haven't played with one yet, just saw a flyer at the supply house this morning. Looks to me like it has potential and I'll be looking for an opportunity to try it out.
03-29-2012, 06:55 PM #6Saw the literature at Jordon Supply... priced out a small one, and they are a couple of times more than a Bohn coil.
Experience is what you have an hour after you need it.
03-29-2012, 07:06 PM #7
03-29-2012, 07:23 PM #8
- Nov 2010
- MN
- 105
Pretty sure the health dept. around my neck of the woods wouldn't go for it.
03-29-2012, 07:31 PM #9
03-30-2012, 06:53 AM #10
- Jan 2008
- Jackson, MI
- 111
I've dealt with them before. Durable and well built. Won't succumb to corrosion from food vapors over time like others. Axial fans on the end it they go bad - simple to replace. Movable vents to more precisely direct air flow.
03-31-2012, 06:04 PM #11Worked on them when I used to do resturants. They worked well salad bars and on cook prep lines.
Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
